Anyone seen a real Slate body panel?
SailorDan
Tybee Is, GA
Not the prototype, which I have read is subject to (possible) change, but the real thing. I am wondering if the shade of gray is the same, for instance, or whether the rough matte surface is a given. I am not against gray in general, but I don't like the flat surface. To me it just looks a bit too much like primer rather than a finished paint job.
I'm undecided on wraps. They seem like a great alternative to paint at first, but longevity concerns and UV damage and fading have me waffling. With wraps the number of colors available (never mind patterns!) is huge, whereas even a car manufacturer that makes many thousand of vehicles a year can only offer a handful of color options in paint. Gray is usually one of them, gloss gray that is.
Any idea whether the flat surface can be shined up a bit with ceramics or polish?
On the subject of wraps. There two types Vinyl and PPF. Vinyl will last 3-5 years if it is garage kept and does not spend extended periods of time in the direct sunlight.
PPF will last 6-8+ yrs if it is kept in the same conditions.
Everything that Slate advertises so far appears to be a vinyl based option. I am definitely going to do a wrap, but won’t decide which until I see their final pricing on the vinyl kit.
Enough PPF to cover the Slate is going to run $600+ to $900+ depending the color and quality.
Not sure that helps, but thought I would share.
Slate Auto Pickup Truck Anyone seen a real Slate body panel? IMG_2891
Add them one swatch at a time. Buy 12”x12” squares in multi color packs or solid colors and make your own pattern. If you have a Cricut or other vinyl cutter you can even cut them in different shapes and sizes. Replace as needed.
I am curious about possibility of Plasti-Dip and the if that material can successfully adhere to the body panels as a potential coating compared to wraps.
Likely a fairly easy test
Vehicle Nanny
Bill
vehiclenanny.com
2014 MINI Countryman; 2025 Ford Bronco
I think it should be fine, as long as the surface is clean and free of wax, grease, etc. I've sprayed it on plenty of plastic emblems with no adhesion problems. I feel the guy at DipYourCar should feature a Slate getting sprayed.
SailorDan
SailorDan
Tybee Is, GA
Yes, that is helpful information, thanks.
Hi Danny, how is your Mom and the rest of the Band? :CWL:
slate808
Mark
HI
Tacoma, Ram
I will be getting the Blank Slate. I actually want the primer gray matte look.
SailorDan
SailorDan
Tybee Is, GA
I wonder if a simple clear coat would work for shiny?
New England
thebluearecoming.com
Slate Auto Pickup Truck Anyone seen a real Slate body panel? 566
My experience with plastidip on cars is after about a year it gets hard to remove. At least on wheels it has been a real PITA to remove.
