Braking in snow
Yes!
I have been driving an EV for over three years now and live in KY where we do get snow. I drive exclusively in full power regen and have never felt the vehicle slip. My F150 Lightning is the most planted stable vehicle I’ve ever owned or driven.
You will learn quickly to feather the go peddle and use it to mange your stoping speed and distance.
Loved the driving behavior of that 6800# brick!
As you guys know, we don’t want to hit the brakes in ice or snow even with abs. As we lift off the pedal in slick conditions will this initiate a slide or will the abs come on and prevent it. I’ve never driven a car with regen braking and don’t really understand how it works. Are my fears unfounded?
Your fears come from a reasonable position, but I'm confident the engineers are aware of the similarities in slippery conditions between regen braking and conventional braking and will have worked around it. If the rear wheels show a much lower speed because they're locked up due to negative torque into the motor while the fronts are free-spinning, the vehicle will detect the difference and request less regen from the motor, allowing the wheels to go faster and avoid a slide. Hopefully it's not too hard (a two-foot driving process) to balance that with hydraulic front brakes.
This is unlike the second-gen Ranger shown in my profile photo (not mine, but I drove one with the same paint scheme) which had rear-wheel-only ABS drum brakes, and as a rear-wheel-drive stick-shift, yes, you could initiate an oversteer situation by downshifting and engine braking just the rear wheels. So you just *don't do that* if you want to maintain control - push the clutch in so the rear wheels free-spin before gently applying the brakes. Adding 200+ lbs of sand or salt in the bed was also a big help, because that truck did *not* have 50/50 weight distribution front and rear.
On the other hand, if you did want to have fun, even with just 95 HP you could dump the clutch and almost effortlessly kick out the back tires in snow! Take out the sandbags and drift like a Japanese racecar... you could practically get stuck in a snowy parking lot in that thing. It taught really good clutch control, because you couldn't move if you weren't gentle!
And no, you don't want to "slam" on the brakes in snow and ice, but you must always be able to gently use them. You might want 10x more stopping distance on a bad day if you don't have snow tires, but you do have to be able to stop, turn, and (if you must) accelerate to move around Michigan in the winter.
d.h.
Bokeelia FL
I think my ice and snow days are behind me. I did a lot of it in my life. Back in the mid 80s I hauled grain in a semi. In those days we only adjusted the trailer brakes up tight, the idea behind it was that with very little brakes on the tractor , the trailer would help keep you straight. It seemed to work . I would think a gentle throttle foot with regen would be what I would try first.
Moe
Moe
Subaru
I’m worried about the regen braking in slick conditions. As you guys know, we don’t want to hit the brakes in ice or snow even with abs. As we lift off the pedal in slick conditions will this initiate a slide or will the abs come on and prevent it. I’ve never driven a car with regen braking and don’t really understand how it works. Are my fears unfounded?
One of the capabilities of Electronic Stability (and traction) Control is reducing the by-wire throttle. If it can reduce that, it can also reduce regeneration.
I’ve never used them on front wheel drive (FWD) or FWD biased AWD vehicles, but I think it is even more important to have well siped winter compound tires on a rear wheel drive (RWD) or RWD biased AWD vehicle on ice and snow. I’ll just park the Slate and take the Subaru with 3PMSF tires. YMMV
Auer
North East
Shoes
Any car driven in snow/ice/cold really.
Those tires exist for a reason.
I suspect even with traction control off stability control would stop you from drifting. I am sure i will test that though and find out. 😁. After all someone needs to for the greater good.
Videos please!
