Home Level 2 charging from generator outlet
I believe Slate truck is 52 kW battery for the low mileage model, little research says 8 to 10 panels to inverter to car battery that would be off grid solar panel
Would love to hear more about your research into this. Any details on the panels and their rated capacity?
pineapple
Arlington, Tennessee
Well, you may want to geek out, cause I was thinking about it ,only if it looks right, and it’s worth the trouble which the answer to both of those would probably be no, but I’m still gonna look into it
Am going to assume you did a good search of this forum for previous discussions?. Some of us discussed last year.
No, not really, I’m new and still learning to navigate this forum. not looking to spend a lot of time on it
Sorry to hear it isn’t worth your time, missing some good stuff.
pdxmotorhead
Dave
Portland OR
I should be all set.
My home generator outlet on the breaker is 50A. I consulted with my electrician friend. Was told I will be ok, just don't poke my fingers on the metal plugs.
I have a detached garage. It has a sperate 40A panel inside. Electrican told me If I want the charger inside or outside from the garage it will be limited to 30A, which is 24A charging.
I been doing some research. I think 24A will be enough for me. Some of the Level 2 chargers on Amazon I found can set charging currents.
I will give it more thoughts. I need the AWD version of Slate. Got plenty of time to think about.
The liability level your jousting with is epic, Insurance companies check for stuff like this, imagine having a house fire and by saving a couple hundred bucks you get your insurance cancelled on claim for illegal electrical mods..
