No, the body panels for the Chevrolet Lumina APV, Saturn vehicles (S-Series), and the upcoming Slate pickup are not made of the exact same material, t
tgpii
Thomas
New Lenox
2023 Chevrolet Bolt.
No, the body panels for the Chevrolet Lumina APV, Saturn vehicles (S-Series), and the upcoming Slate pickup are not made of the exact same material, though they all use non-metal composites designed for dent and rust resistance. [1, 2]
While all three utilize a steel spaceframe to which exterior plastic panels are attached, the specific plastic composition differs based on the technology available at the time of manufacturing. [1]
1. Lumina APV (1990–1996)
  • Material: Sheet Molding Compound (SMC).
  • Description: This is a fiberglass-reinforced thermoset composite. It is a rigid, dense plastic designed for high-volume manufacturing.
  • Context: It was used for its ability to resist dents and rust, covering the steel structure of the "Dust Buster" minivans. [1, 2, 3]
2. Saturn (1990s–2000s)
  • Material: Thermoplastic Alloys and Reinforced Plastics.
  • Description: Unlike the rigid SMC, most vertical Saturn panels used a type of flexible, tough thermoplastic (sometimes referred to as polycarbonate-based) that was exceptionally dent-resistant.
  • Context: Like the Lumina, these panels were bolted to a steel "spaceframe". [1, 2]
3. Slate Pickup (2026 Model)
  • Material: Injection-molded Polypropylene Composite.
  • Description: Modern polypropylene is a thermoplastic that is durable, lightweight, and recyclable. Slate specifically uses this to avoid the need for paint, using unpainted, dyed-through material that can be wrapped.
  • Context: Similar to the old Saturn approach, the panels are non-structural and meant to be easily replaced. [1, 2, 3]
Comparison Summary
Feature [1, 2, 3, 4, 5]Lumina APVSaturnSlate Truck
Material TypeSMC (Thermoset)ThermoplasticPolypropylene (Thermoplastic)
FiberglassYesSometimesNo
Panel TypeRigidFlexible/ResilientDurable/Reusable
UnpaintedNo (mostly)NoYes (standard)
While the philosophy (plastic panels on a steel frame) is identical—often citing the Pontiac Fiero as the predecessor—the materials have evolved from 1990s thermoset composites (Lumina) to more modern, flexible thermoplastics (Saturn) and, finally, to modern, unpainted polypropylene composites (Slate). [1, 2, 3]
Slate Auto Is Building The Anti-Gigafactory - The Autopian
Apr 28, 2025 — Slate Auto's first plant doesn't sound anything like a modern car factory. Right off the bat, there's no paint. Just last year, Toyota invested $922 million to ...
The Autopian
I Laughed at Plastic Panels, But The Slate Truck Silenced Me
Jun 20, 2025 — The Slate truck uses plastic body panels to reduce manufacturing costs, simplify assembly, and improve durability. These panels are made from injection molded p...
Torque News
Everything You Want to Know About That Slate EV Pickup | WardsAuto
May 5, 2025 — To eliminate the cost of investing in a body shop in the assembly plant, Slate uses molded polypropylene body panels. And to eliminate the cost of a paint shop,
WardsAuto
Did you know that Saturn cars were made out of mostly plastic ?
May 18, 2021 — I now own a 2009 saturn aura. Hope it lasts as long as I do. ... Jimmy Don Holland Jr. ... another fun fact: they weren't really made on Saturn. That was just m...
Facebook·Car Museum
Question about the body panels.
Apr 26, 2025 — New Member. Joined Apr 26, 2025 Threads 1 Messages 3 Reaction score 4 Location Lewisburg, TN Vehicles 2005 Hummer H2, 2014 PriusC. Apr 26, 2025. I've got my res...
www.slateforums.com
The story behind the Chevrolet Lumina APV minivan's creation - Hemmings
Feb 19, 2021 — One thing Ruzzin's team had no control over was the decision to build his vans using a metal space frame and to construct the body panels out of injected-molded...
Hemmings
17:42
I BOUGHT A $700 Saturn SC2 It's Mostly PLASTIC In The BEST WAY
YouTube·WatchJRGo
The new Slate truck costs less than $20,000, uses PP composite body ...
May 14, 2025 — The new Slate truck costs less than $20,000, uses PP composite body panels. Stylish vehicle EV pickup model is supported by a simplified manufacturing process. ...
Gardner Web
1990–1996 Chevrolet Lumina APV: Specs, History, Trims - Moto Gallery
Sep 9, 2025 — As with any period GM automatic, routine fluid and filter service pays dividends; solenoid and valve-body issues can crop up on high-mile examples. Body/structu...
motogallery.com
Chevrolet Lumina APV - Autopedia | Fandom
The Lumina APV featured body panels of fiberglasslike composite bonded to a steel framework. There were Base and CL editions, and both models could seat up to 7...
Autopedia | Fandom
AUTOMAKERS GO PLASTIC - Chicago Tribune
Aug 20, 1989 — Plastic hoods, deck lids, fender extensions and fascia panels have been used on cars for a couple of decades. The body of Ford`s Taurus SHO is all plastic from ...
Chicago Tribune
Aug 20, 1989 — More recently, Pontiac tried a different and innovative approach with its Fiero mid-engine sports car. The Fiero had a steel ”space frame” to which plastic pane...
Chicago Tribune
We Got Inside the Slate Truck - And It’s Bigger Than You Think
Oct 20, 2025 — We got to sit in the Slate Truck! Here's a first look at the interior design, materials, tech, and layout, plus a more detailed preview of what the #SlateTruck ...
YouTube
Slate Auto Pickup Truck No, the body panels for the Chevrolet Lumina APV, Saturn vehicles (S-Series), and the upcoming Slate pickup are not made of the exact same material, t 1777516638687-z
Comparison Summary
The Autopian
Torque News
WardsAuto
Facebook·Car Museum
www.slateforums.com
Hemmings
17:42
YouTube·WatchJRGo
Gardner Web
motogallery.com
Autopedia | Fandom
Chicago Tribune
Chicago Tribune
YouTube
You are very talented at cluttering up a forum.
We really need to stop posting results from AI. Posting them anywhere.
The problem is that if an answer is not to be found, AI bots will make stuff up. It is unintentional, but in training the models, not finding an answer is given a low score, and the systems are designed to eliminate low scores.
If an AI result is posted, that possibly erroneous post is then used as a reference in future AI searches. If it could be tagged as an AI result in such a way as to not be used, it wouldn't be such a problem.
Notice that 2 of the references in the post are to other posts here on these forums.
How far could you drive a Slate on the amount of electricity wasted from posting slop here?
Vehicle Nanny
Bill
2014 MINI Countryman; 2025 Ford Bronco
Oh give the OP a break. Every bonehead on this forum, including me, has been cluttering this site with made-up BS for the last year. Because there have been maybe five actual facts to discuss during that time period.
Spot on!
Later Smart cars used injection molded TPO though, which is basically a durability enhanced polypropylene. So at least very similar to Slate, who hasn't gone into any detail on their specific PP blend. However, Smart still added at least a (gloss durability enhancing and UV protecting) clear coat even on their few base molded-in-color (black, white, and light yellow) panels. Despite their ability to MIC, all of their other colors still just used panels molded in black that were then painted. It'll be interesting to see how unprotected vs protected Slate panels compare over time.
tgpii
Thomas
New Lenox
Maybe that is why slate is so pushy about selling you a wrap?
