I wonder when we'll see a completed truck off the line? That would normally happen 6 to 12 months ahead of first delivery. Maybe they already have some, and are just not showing them to the public before the big announcement day? You gotta keep some "ooh" factor in reserve.
GrizzlysGhost
Montana
I suspect the great majority of builds (with the exception of maybe one or two rolling samples) for the next few months will be reserved for demolition on the Safety Course.
Great video, narrated by Jeff Jablansky, head of PR and communications at Slate.
I still recall that famous line where he says,
“This is narrated by me, Jeff. I work at Slate and just happen to have a great voice.”
Chris Barnan: “He really does”
I think this is paint booth/oven? They need to paint and cure the frame somewhere. I know asking for SS would be too much, but with plastic panels it would last forever.
The frame will be ED coated (dipped in a solution, electrically charged so the coating attaches, then baked to cure it on). They still won't have any conventional paint spraying booths.
KJRaven
You're right, sort of! The frame absolutely needs a coating applied, and that area definitely looks like the frame coating setup.
My guess is Slate will use an E-Coat process for the chassis, which is a much simpler than a traditional automotive paint shop. Instead of using spray guns to shoot 14 different cosmetic colors with metal flakes or matte finishes, an E-coat setup basically just dunks the metal parts into a liquid bath to bond a single, protective layer to the frame.
Because they don't need a massive, multi-stage cosmetic paint department, a single-color frame dipping line is way smaller, cheaper, and more space-efficient.
EJensen
Northern Virginia
Subaru Outback
Nah, those looks like carriers for some process of the assembly. Some have the Flexlift labelling visible which is a brand of lifting platforms. You can see several of them staged on the line in a later shot
Got it. Thanks for the insight.
EJensen
Northern Virginia
Subaru Outback
Wow, really? How many units need to go through that?
BobbyMcGee
BobbyMcGee
Toyotas
Did anyone see any sheet metal stamping machines?
GrizzlysGhost
Montana
Admittedly my knowledge on this subject is solely based on heresay and google, which indicates between 30 and 50 units; but my gut tells me it might be more as this is a brand-new platform and may require more trials to get it right.
Slate Auto Pickup Truck Slate factory up and running - photos & video (A New Day in Warsaw)!! 👷‍♂️🎬 1781217334043-5l
