So, these floating body nuts look like the nut-side of the rear fender fastening hardware based on these locations of the frame standoffs (red). The three in yellow look like some of the "hidden" fasteners that Slate says are the ones to prevent body panel theft.
Slate Auto Pickup Truck Slate Ladder Frame close up pictures! Rear-corner_nuts
I saved them all to my Slate file folder on my computer. LOL.
Seems the body panel engineering here is a bit better than the Cybertruck where some of the body trim panels de-glue from the chassis and fly off at 60 MPH. :CWL:
I'm counting at least 100 parts (of the 850) go into building the just Slateboard frame. 🤣
I hope others here see the artistry in this like I do. This is where the quality of the product starts. I'm very encouraged.
They look to be a tab that is formed flat with the rest of the panel then angled up.
Ah, I should have zoomed in. I see it now. The under layment of opening to stamp the tab cutout tricked me. It's part of the center console baseplate that sits over the main floor pan.
Thanks.
Just look at the quality of the frame welds using the laser welding robots! The 3D laser scanner below locates parts down to 1 micron precision, which is the decimal equivalent of 0.000001 meters.
Slate Auto Pickup Truck Slate Ladder Frame close up pictures! IMG_2983
Hard to tell in that picture how it sits in the bed, but I will trust your research.
If you look at the Bedboss website, you get a better idea of what it is. It's a floor plate made of a hard plastic composite with a structural foam core. It has mounting brackets that bolt the Bed boss to the pickup box. It has two rails of anchor points for tying down loads. It's a nice piece of kit if one needs more options for tying down cargo and adds a bit more load floor protection.
The level of engineering and industry knowledge demonstrated by Slate is why I have more faith in them to get these done. Most startups spend all there time and money just advertising trying to get startup money. Slate is just jumping straight into what actually needs to be done.
The amount of industry knowledge in their staff really shows.
Johnny-Longtorso
Don
Tampa
I'm not an expert in assembly line robots by any measure - but the placement and alignment of some of the spot-welds don't exactly scream "robotic precision" to me.
Slate Auto Pickup Truck Slate Ladder Frame close up pictures! 1783088837809-io
