Good catch. I'm thinking the rolling brick comparison that seems to be popular might not be so accurate.I'm also surprised that the windshield is steep in comparison to those alternatives!
I had chat gpt create an overlay of current trucks that are of small size in the USA. Gives an idea. Obvious you’re one that can’t be pleased. I hope you enjoy your miserable life.You need to make an apple to apples overlay of 2 door small trucks, anything else is BS.
Thank youI had chat gpt create an overlay of current trucks that are of small size in the USA. Gives an idea. Obvious you’re one that can’t be pleased. I hope you enjoy your miserable life.
As much as the 65kWh LFP was the right choice, I do lament the increased capacity and drop in energy density bringing that weight figure up by ~440 pounds. 😢The Slate is a 4" taller, 3.5" wider, 1" shorter overall, 1" longer wheelbase, and about 1,025 pounds heavier. Round numbers.
I matched it against the 1st Gen Ranger because I had a new 1987 STX back in the day and was curious how the dimensions stacked up.As much as the 65kWh LFP was the right choice, I do lament the increased capacity and drop in energy density bringing that weight figure up by ~440 pounds. 😢
At least, I hope you're using the 4048 figure and not the old 3602 one for that. At least battery weight is low, at least it's low, at least it's low...
