OldGoat
For me, the announcement of 210 range was very welcome. On the coldest days we have that still leaves me 150 miles. Which is plenty on 90% of my drives.
Perhaps you should consider a Lexus.The Slate is a great vehicle, but not without some shortcomings that would be welcome in extreme cold conditions:
1- no heated seats
2- no heated steering wheel
3- no heated defroster in the rear glass window (SUV)
4- no rear wiper (SUV)
We've heard that heated seat elements might be coming soon via third party, but I still have some concerns about rear outward visibility when bad weather strikes.
1 - likely add onThe Slate is a great vehicle, but not without some shortcomings that would be welcome in extreme cold conditions:
1- no heated seats
I had a question to that effect from my western Washington perspective. I asked about battery heating because LFP shouldn't be charged when too cold (typically below about 0C to -5C). I asked if the Slate pack had heating, as I had heard elsewhere that the heat pump could be used to cool the pack. The response was a vague non-answer, "our team has explored the possibilities and provided solutions." That reply was in early July of this year.I haven't seen a thread about the extreme cold effects yet, but as a guy who goes by Frozen North, you can guess I'm real curious. We routinely see temperatures between -10 and -30 up here.
Those temps are why I've never bought an EV up here.
And yes I know buying a two-wheel drive isn't optimal in a climate that has nearly 6 months of winter.
Snow tires and common sense can overcome most winter hazards.
I would love to hear from someone who has experience living in an environment with winters as harsh as we get in Northern Montana ,North Dakota, and Minnesota.
1 - already exist. Amazon all day. You can get them with massage, too.1- no heated seats
Only within a certain temperature range. That's why most residential heat pumps have resistive or gas supplemental heating. At freezing and below their efficiency drops below that of the "less efficient" alternatives.Depends. With heating you can do a heat pump or a resistive heater. Heat pumps are way more efficient than a resistive heater.
Thanks for the correction. I'll have to look into why I've got that flipped in my brain it seems.
iirc, most the EVs running heatpumps use the battery packs as the/part-of-the heat source.The Slate uses a PTC Heater vs Heat Pump. In extreme cold temperatures, a PTC (Positive Temperature Coefficient) heater will work faster and more reliably than a heat pump, but it will consume significantly more battery power. Draining range. A PTC heater uses direct resistive heat, acting like a giant hair dryer, whereas heat pumps struggle to draw warmth from the freezing outside air....
