Perhaps they were different generations of test vehicles?
The harlequin one is definitely an older iteration. Some other tells are the pass-through panel on the back of the midgate, and the NACS cover with the angled corner instead of square.
Slate Auto Pickup Truck Slate x Crayola Block Party Pictures from NYC! -- July 11, 2026 43058-388f0e87c8f17ef8aa7e55e7bfff9851
EVfun
Does anyone know what the wheels look like under the wheel covers? Some type of wheel cover seems to be on all the ones with the standard 17 inch wheel.
I think that is the actual steel wheel. The only cap is over the lug nuts in the center.
EVfun
I want to give a big Thank You to Pluglyf for the new images!
Initially I thought that too, but this photo Pluglyf makes it look like the center cover extends outward over the wheel as a partial areo cover. There appears to be an edge to ring around the center cap if you look toward to the top of the image. It is possible that is an illusion.
Slate Auto Pickup Truck Slate x Crayola Block Party Pictures from NYC! -- July 11, 2026 aeRxPHPGua2eEUXV0ZFHs_hQB_BGVXtu9g=w1234-h929-s-no
I don't think so. That's just how the steel wheel is made. Since it has 1-PD, there's no real need to put ventilation holes in the wheel.
According to Gemini as much as I hate AI answers:
The standard, factory-issued wheel on the Slate EV is a basic one-piece steel wheel designed to match the vehicle’s stripped-down, ultra-utilitarian, budget-friendly aesthetic.
It comes finished in a dark color and features a small, basic center cap that covers the lug nuts and the central hub, leaving the rest of the rugged steel wheel completely exposed.
According to Grok:
The base model comes with 17-inch black-painted steel wheels (17” x 7”, paired with 245/65R17 tires). These are described as a simple, flat-faced or basic stamped steel design.
• Forum users who inspected display vehicles (e.g., at events like in DC) reported knocking on the wheels and confirming no wheel covers, hubcaps, or center caps—the exposed wheel face with visible lug nuts is how they come from the factory. One noted: “there were no wheel covers or hub caps, what you are seeing was the actual wheel.”
I saw the Slate on display in DC last October. I was curious about the wheels and knocked on the surface that gets the decals and it was solid. My conclusion was it was part of the wheel and not a cover.
The center cap has a notch, probably to make it easier to remove
Slate Auto Pickup Truck Slate x Crayola Block Party Pictures from NYC! -- July 11, 2026 Slate_Wheel_Center_Ca
Are those the actual lug nuts poking through the cap with the (not-so-consistently applied) lighter-gray paint on them?
Rocks
AZ
Maybe Slate
Doubtful. Probably just molded into the cover.
