Suggestions for first-time pickup owner?
Maverick has a nice in bed cubby. I was able to add one to my Tundra. That’s the part #. Very handy for couple of straps, gloves, etc. Hop I can do same in my Slate
That is pretty slick. It looks like you cut a small square hole, the feed the cubby body down into it (going between the bed wall and the outer body panel), then screw it down? Seems like it would be compatible with a lot of trucks as long as they have a spot with a mostly-flat panel and a little depth behind it. Cost is only ~$40. https://www.fordpartsgiant.com/parts/ford-partition-loading-compartmen_nz6z-60286a72-a.html
Any install notes I'm missing?
EDIT: Even better photos in this ebay listing (no affiliation): https://www.ebay.com/itm/406693327248
Thank you
my details and more here: https://www.tundras.com/threads/inbed-storage.153954/
sincerely hoping i can add 1 or 2 to my Slate
thespacecowboy
Georgia, USA
1964 Dodge Dart, Fiat 500L
Just read through the thread you linked to on the Tundra forum. I like this idea a lot. A 5' bed isn't very large once you start keeping anything in it, so a small cubby that doesn't eat into the available space is nice, and could be a great way to keep straps and the like available. How does it do with liquid? Is it sealed?
I haven’t had a problem. Unit dose have drain type hole in bottom that I intended to seal and forgot, but haven’t experienced and wetness inside.
Mac-Tyson
United States of America
The only thing I have besides what you’ve listed is a cargo net that I use occasionally when I’m hauling loose stuff that might blow around.
Though to OP as a new pickup truck owner you should be aware some of the loose things you will worry will fly out, actually won't. You will be surprised on what you can throw back there and be just fine having it back there. But cargo nets are great as well just don't think you need one every time you are hauling loose stuff that isn't super heavy.
Most of my advice about pickup truck ownership growing up is all but solved by Slate having that frunk. Most of it was going to be about keeping stuff behind the seats so it doesn't
get taken, blown away, accidentally rained on.
The Maverick is also prewired for accessories to said cubby, and other common locations where people like to install lights, compressors, etc. And has a power outlet on my lux package. Which I used during hurricane Helene to run a small electric coffee grinder and pot. OTOH, since Slate body panels can literally unbolt, seems to me that wiring is gonna be pretty easy?
BTW, when you've had the power go out in an entire region for multiple weeks, you realize that BEVs are just as vulnerable to catastrophes as ICE. Unless of course you have solar panels and can disconnect from the grid. Which is why we now have a whole house generator (and will add solar in a few years).
One for doggie kibbles and the other for water? 🐶
I'm thinking it's really a sub enclosure. @sodamo pups like to ride around the island thumpin'. He need's to come clean with the TRUTH!
Mac-Tyson
Slate really solves the two big issues Single Cab Pickups had and why they dropped to being only 3% of the Pickup market. There are a lot of reasons why Crew Cabs became dominant but two main ones are that they became too expensive to comfortably be a second vehicle so you needed your truck to do more to justify it (Ram CEO calls it the Spousal Alibi) and 2nd backseats provided actual locked storage. Slate solves both these issues.
thespacecowboy
Georgia, USA
The thing previously holding me back on getting a truck is that I want a single cab but it would be a primary vehicle and I need to throw groceries and the like some place other than the bed. A frunk easily solves that complaint for me. I just dislike the look of crew cabs on a truck, and I don’t have a need for more than two seats generally. I’d love a bench seat for some flexibility, but that would be the only change I’d make to a single cab.
Ok, truth is… we have to be careful taking them in my Tundra, mindful of the weather, overheating if parked too long kinda stuff. Thinking EV, with the integral topper, will have to option to possibly run the AC, not something I’d do with ICE.
also, they have a ramp for the Tundra bed, too high to jump, not good for joints to jump out. The lower bed Slate ought to be sweet.
As everyone gives their two cents: here is my truck box contents:
Tool kit (basic set for vehicle maintenance, situational repair needs)
First Aid kit
EM Road kit (fix-a-flat, air pump, flares/lights, jumper kit
assorted vehicle fluids
tow hitch
Rain Suit/jacket
gloves
safety glasses
spare ball cap.
Assorted Zip ties
Assorted carabiners
Assorted bungee cords
ratchet straps
rope
two tarps (good for temporary liners or cargo net/cover)
padding/ground blanket
I will probably adjust this if i follow through on Slate purchase.
in addition to the above
1) chamois
2) paper towels
3) umbrella
4) spare shoes, socks, shirt
5) stainless steel 64 oz water
6) spool of wire (e.g. florists wire) - like it better than rope
7) extra 9mm ammunition
8) small camping stove and fuel tabs
9) water filter
10) dry snack bars - I use emergency ones that last forever
11) whistle
12) backpack
My first aid kit has a few things for a car crash
1) israeli bandage
2) clotting powder
3) self adhesive bandages
4) big gauze pads
