Coolant and Brake Fluid Type
Is there any word on what kind of coolant and brake fluid will be used? Hopefully the coolant system is easy to DIY every 3 years or so. DOT 4 LV brake fluid should be the standard though with regen, wet boiling point specs shouldn't be too big of a concern.
KJRaven
the data sheet for the drive motor that looks to be the one slate is using (https://www.slateforums.com/forum/t...gwarner-in-slate-prototype-video.13170/)calls for a 50-50 mix of water and Ethylene Glycol for both the motor and inverter (https://www.cascadiamotion.com/idm-190.html)... so it is your typical green very basic coolant, I would assume that the battery would use the same coolant if it is water cooled.
you are likely going to need a vacuum filler to purge the air out if you were to DIY it.
Slate Auto Pickup Truck Coolant and Brake Fluid Type 1750169963451-10
50/50 is pretty typical for most cars. I guess I'm more curious about the type of coolant like a HOAT, OAT, or IAT. One thing I hate doing is messing with coolant changes. They're always so messy unless using a Venturi valve, which I conveniently have.
KJRaven
yep, coolant changes are messy! Hopefully they use a long life coolant that we dont need to mess with for 10+ years. One of the reasons im excited about EVs is because of the reduced maintenance, so the less I need to do to maintain this truck the better!
If the radiator has a petcock or a downward facing drain plug, coolant drain and fills are no messier than an oil change. Last one I did didn't get a drop of coolant on the ground.
It's when you're really opening up the system (removing hoses, thermostat housings, pulling radiators, etc) that stuff really gets messy imo
I would think draining and filling an EV battery cooling system is complicated and probably needs a manufacturer-based service software tool to operate the various valve bodies in the system to fully drain and fill the system.
It definitely depends. I’ve serviced BEV coolant systems on HD trucks. Some do, some dont
