- Nov 7, 2025
- 3
- 305
- 501
- New England
- Website
- thebluearecoming.com
- '21 Kia Seltos 2.0 AWD
- Thread starter
- #1
I've a question that I hope someone in the EV sphere can answer. What part of the Slate's electrical system will power the HVAC - primary or secondary ?
A DC motor to run the AC compressor off 12-Volts is less expensive than a motor and motor drive needed for the primary high-voltage side. It would be safer to run electric heater coils off 12-Volts.
However, the current demand to run HVAC off 12-Volts would be huge. So any cost savings you get by using cheaper 12-Volt parts will be offset by the monster DC-DC converter needed to run them. And you can count on a 10% efficiency hit from a converter like that, to boot.
Or maybe Slate uses a 42-Volt converter for HVAC. That would use about 1/3 the current for the same power, and still be a lot safer than connecting directly to the high-voltage primary.
So... does anyone know how the HVAC will be powered ?
