Playing devil's advocate here, comparing Slate Truck vs. Ford Maverick
YDR37
The cheapest possible Maverick does not satisfy those requirements -- but they can be met by adding just $125 to the base price.
According to Ford's build & price website for the Maverick, the least expensive option is a base XL with FWD/2.5L Hybrid engine for $30,535 (MSRP plus all fees). OK, this configuration only has 191 hp, so slightly below the OP's "200+ HP" requirement.
But the XL can be switched to an AWD/2.0L I-4 Ecoboost (turbocharged) configuration for only $125 more. That configuration has 250 hp, with towing capacity of 2,000 lbs. Total cost is $30,660 (MSRP plus fees). Would seem to meet (and exceed) the requirements.
Correction: the "2K Trailer Hitch Receiver with 4-Pin Connector" isn't standard on the XL, it's an additional option for $100. So you would actually have to add $225 to the base price, and so the total rises to $30,760 (MSRP plus fees).
Memphis
MAVs are selling at employee price (below MSRP) right now, with no haggling.
YDR37
For example, this dealer in Missouri is currently advertising a new 2025 Maverick XL AWD with the 2L EcoBoost (250 hp) for $27,636. The ad doesn't mention the 2K tow hitch, so you would probably have to budget another $100 for that.
YDR37
But even the hybrid XL Maverick at 191 HP weighs less than the 201 HP Slate will and will have a better power to weight ratio.
Yes, the hybrid Maverick could realistically perform as well as a Slate, despite its lower hp, given the likely greater weight of the Slate. For example:
Maverick with 2.5L Hybrid, 191 hp: 0-60 in 7.7 seconds (according to Car and Driver)
Slate with single electric motor, 201 hp: 0-60 in 8.0 seconds (according to Slate).
A Maverick with the turbo I-4, 250 hp, is significantly quicker than either, with 0-60 in 5.9 seconds.
Memphis
Our hybrid AWD lariat is quick enough. The electric motors’ instant torque combines with the ice when needed. It also goes full ev mode when it can, with some trips at lower speeds running the ev only maybe 30% of the time. To ford’s ( and Toyota’s) credit it’s seamless between ev and ev+ ice and ice only.
I maintain that the mav is NOT the slates main competition. It’s not an EV!
Slate will be compared to Bolts, Kia EVs, Hyundai, and VW EVs. All the 25-35 k entry level EVs that are due out in the next year or 2. Some serious competition like the bolt and ev4.
Kia Forte Koup
Well, I will keep the upgraded Maverick and Compass in mind when the time comes for me to buy, but there is nothing indicating that they will be less expensive than the Slate, especially once you figure in the about $3k delivery and dealer fee. If they are all in the mid twenties, I would likely get a Slate just because it's electric.
I have also looked into the other EVs, after all "truck" is not in my list of requirements and some of the EV cars are rated for towing, but I haven't had much luck there...
All that said, I scoff at those who bitch that Slate has no infotainment installed. Frankly, my phone is a better infotainment system than I've seen in any vehicle at any price. We have an infotainment system in our family car and we never use it.
Karl Childers
Karl
Auburn, WA
I own 3 Maverick hybrids. The price of needs to be below $20k to compete. Made a 55 mile backroads run this morning 47 MPG.
My morning commute in our 23 Maverick hybrid. Going home i usually get 42mpg. I want a Slate to add to the stable.
Slate Auto Pickup Truck Playing devil's advocate here, comparing Slate Truck vs. Ford Maverick 20250610_054850
A Slate charged on the public network would cost $2.80 more to go that 55 miles.
A Slate charged at my level 2 charger in my garage would cost $1.22 to go that 55 miles assuming the 2.8 miles/kWh efficiency. I’m optimistic that it will be closer 3.2 miles/kWh due to listing max battery capacity and not usable.
I said "charged on the public network". My number is 0.45 kWh and $0.06/maintenance for EV.
So is your position that it will be more expensive to operate the Slate than it would be to operate a Maverick? That is certainly the polar opposite of my experience with 2 different EVs over the last 7 years.
I find that position extremely difficult to believe true.
Below is the expense report for my 2018 Tesla Model 3 since I bought it new. Average operating expense(maintenance) to operate has been 3.8¢/mile. This is by far and away much cheaper than any ICE vehicle I've owned in 38 years of vehicle ownership. Electricity expense has been 3.1¢/mile which is also cheaper than any gasoline expense for any ICE vehicle I've owned. Even cheaper than the 1992 Saturn I drove from 1992 to 2004 with an average gas price of $1.10/gallon which got an average of 31.5 mpg in the 177k miles we drove it. Provided you are not reliant on DC fast charging for your daily driving needs, I would submit that the Slate will be cheaper to operate than the Maverick by a wide margin. If you are reliant on DC fast charging for your daily driving needs then it will be much less of a financial benefit to switch to EV and it might be advisable to stick with an ICE vehicle as I can't imagine visiting DC fast chargers that frequently is worth the cost savings for most. Just my 2¢.
Slate Auto Pickup Truck Playing devil's advocate here, comparing Slate Truck vs. Ford Maverick 1749599623990-yk
No offense meant, but JFC, I said when the Slate is charged using the public network. According to the Poster, his Maverick Hybrid gets 47 MPG. The public network charges around 45-cents per kWh according to the internet and what I've read as reported by Mach E owners on the Mache E Forum. It's just simple mathematics.
If you keep relating your numbers to an EV charged at home at the national average of around 13-cents per kWh, the mathematics that generate my numbers will not make sense to you.
Thanks. I did understand you were referring to public charging and I was providing what I believe is a more likely scenario. My electricity costs do include some DC fast charging when on trips. Incidentally, your 45 cents per kWh would be a public DC Fast Charging rate and not a Level 2 public charger which would be around 20 cents per kWh. I think your math indicates that if your plan is to buy a Slate and utilize 100% public DC fast charging infrastructure then it is probably more cost effective to buy a Maverick instead.
