Taller 17" All-Terrain Tires for OEM Wheels
The Dude
Willys
Will a 30.9 fit without rubbing the inner fenders? Anybody know if the plain steels will come in 17's?
For the 235/75R17 size it might, because of narrow width. Generally speaking, narrowness permits more height without rubbing.
The Toyo AT3 in the photo is an example.
It fits, but couldn't be wider. If I wanted wider I'd need either a lift or a smaller diameter tire, if that makes sense.
There could be some wishful thinking kicking in. :)
A specific tire's tread width (as opposed to its sidewall "section width") makes a significant difference. For this reason two tires labeled as the same size, but having different shapes / tread widths, could fit and not fit.
PACMAN
Maverick Hybrid, KLX300SM
Excellent choice.
I've decided the 235/75R17 (30.9" x 9.3") seems to be the "Goldilocks" All-Terrain tire size
There's a very good chance that size wouldn't require the Lift Kit.
Appearance-wise it'll fill the fenderwell more than the stock size, which already fills the fenderwell better than most stock pickup tires do.
245/70 is indeed another Goldilocks size, just trading some height (-0.4") for width (+0.3").
I prefer narrow AT tires (pizza cutters!) because they perform better and that's the Absolute Truth. (JK ;))
FWIW, I have a set of 33"x10" Toyo AT3 tires and they're fantastic.
They're made in one of United States (Georgia). 🇺🇲👍
You make a lot of good points! That 235/75R17 really is a great size, especially if you’re really looking for traction. I’ve had pizza cutters on 4x4s in the past, and I’m a believer 🙂.
Also, I bet you’re right about not needing a lift in that size. The slimmer width will gain you some clearance.
I’m kinda surprised that Slate is using 245/65R17 as the stock size—that’s not a small tire. My Maverick comes with 225/65R17s.
It’s cool that the Toyo’s are made in the US; I didn’t realize that.
Let’s keep this tire thread going. Right now, my number one contender is this Toyota Open Country AT3 in 245/70R17, because it’s quite light, and I think it’ll look plenty big on the tiny little truck. Pic & specs below. I’d probably look for some 8” wide alloy wheels for them. Has anyone else been picking out tires?
I'm a tire noob, so excuse my ignorance. The Slate is a light-duty truck not intended for heavy off-road usage, by nature. Why put a AT3, a pretty hefty off-road tire on it, as opposed to something more highway oriented?
Obviously some people will push it to the limit, but I would think most people are going to be putting nearly all their miles on-road with this, why not tailor tires to that? Just appearnce?
PACMAN
For me, it’s mostly appearance. I also like the added traction for rain, snow, wet grass, and forest service roads. One way to help maintain range is to get modest-size, lighter all terrains.
Without a doubt. This is more of a factor than I would have expected before looking into it.
Having a tire that's close to the weight of the OEM tire also presumably helps the suspension work better because, for example, that's the weight the spring was designed to push back down when a bump pushes the tire up, if that makes sense.
Makes sense. I love me some white lettering KO2s.
I've had my family sedan on 2 tires, bottomed out enough times that I probably don't think enough about tires.
I learned about the virtues of "Pizza Cutter" tires a long time ago, before they were known by that name, from a hunting guide who had a lot of off-road experience. Since then the topic has been discussed ad nauseam online.
My conclusion: Wide tire look better but narrow tire work better, with exceptions that don't apply to a Slate Truck (very deep mud and very soft sand).
Now when I see a truck sporting pizza cutters I get that "if you know you know" feeling. :)
To accelerate your understanding of the arguments (on both sides) go to YouTube and search for [pizza cutter tires] and read comments below the videos.
Here's a good pseudo-scientific explanation that, just by coincidence, affirms my existing beliefs ;) :
PACMAN
Hey AZ Fox, it sounds like we’ve had some similar experiences. Most of my offroad “knowledge” comes from elk hunting back when I lived in CO and MT. I also did aome offroading when I lived in Flagstaff for a couple of years. Now, I have a little Kawasaki KLX300SM with knobby tires that’s my go-to offroad machine. I see in your profile you have a Honda NC700X. Do you get that thing off the pavement much? (Off topic, I know.)
PACMAN
Experiences like that make for good stories!🙂
ProTip regarding Toyo Open County AT III tires:
The OWL (outline white letter) and BSW (black sidewall) versions in a given size are not the same tire because the white lettering isn't the only difference.
The BSW tire has larger lugs (same pattern, just larger and with wider gaps) and it has a beefier, more aggressive sidewall. The OWL version lends itself slightly more toward highway driving.
The OWL version is only available in some sizes, including the Slate's stock tire size (245/65R17). In that size it's listed at two pounds lighter than the BSW version.
Slate Auto Pickup Truck Taller 17" All-Terrain Tires for OEM Wheels AT3_OSW_vs_BSW
Somewhere I read that the OWL tires may be manufactured in Japan, however in another place I read that all Toyo tires sold in the US are manufactured domestically, so who knows.
Slate Auto Pickup Truck Taller 17" All-Terrain Tires for OEM Wheels The_More_You_Kno
Photos of a demo Slate with 245/75R17 tires and a 2" lift are in this thread.
Repeating what I wrote there:
That's a 49-pound tire. It's probably ~15 lbs heavier than the stock tire. It's also 2" taller. Gotta wonder how much that affects acceleration, braking, and range.
235/65R17 is ever-so-slightly smaller than the stock size, so it lacks the drawbacks of installing larger-than-stock sized tires (if you don't choose a heavy one).
it's a common stock tire size for SUVS, so there's an abundant selection of appropriate-weight Standard Load and Extra Load All-Terrain tires to chose from.
As an aside, there are lots non-AT tires available in this size too, including Michelin's popular CrossClimate2 and CrossClimate SUV tires with their attractive pointy tread pattern. There's also a Bridgestone run-flat All-Season touring tire available.
The width is 1/3" narrower than the stock 245/65R17 size.
The diameter is 1/2" smaller than the stock 245/65R17 size.
235/65R17 (29x9.3) - Speedo Error: 49.2 @ 50mph (-1.7%)
BFGoodrich All-Terrain T/A KO3: 45 lbs, 29.1" (Load Range D)
BFGoodrich Trail-Terrain T/A: 29 lbs, 29.1" (Standard Load)
BFGoodrich Trail-Terrain T/A: 36 lbs, 29.1" (Extra Load)
Falken Wildpeak A/T3W: 31.1 lbs, 29.1" (Standard Load)
Falken Wildpeak A/T4W: 38.2 lbs, 29.1" (Standard Load)
Falken Wildpeak A/T Trail: 32.5 lbs, 29.2" (Standard Load)
Falken Wildpeak A/T Trail: 35.1 lbs, 29.2" (Extra Load)
Toyo Open Country A/T III: 34 lbs, 29.1" (Extra Load)
Goodyear Wrangler Workhorse AT: 30 lbs, 29.1" (Standard Load)
Heaviest tire: 45 lbs
Lightest tire: 29 lbs (16 lbs lighter!)
235/65 and 245/65 visual and data comparison:
Slate Auto Pickup Truck Taller 17" All-Terrain Tires for OEM Wheels 235-65-17_Compare_Stock
Slate Auto Pickup Truck Taller 17" All-Terrain Tires for OEM Wheels 235-65-17_DataCompar
I just wanna put CC2s on it...
Amen! I have them on my Tesla 3 (RWD LR) and we liked the performance so much got a set for my wife's Honda Accord. IMHO they outperform the cheaper snow tires here in Michigan.
