- First Name
- David
- May 19, 2025
- 8
- 1,392
- 1,791
- Big Island Hawaii
- Tundra 1794, Subaru Ascent
Agreed, but I think the pervasive mindset is things are replaceable, not repairable. Many of use grew up in the repairable era. We need return to that thinking.EVs are sooooo much simpler. Simple? eh....no, holistically. But simpler? oh yes. You're just not used to them is all. Maybe thats part of the issue? There's so little there to work on that it seems like it must be a 'black box' - its not. Theres just not that much to them. Youre used to seeing a lot of things inside moving in a 'motor' not just coils of wire. :/ And yes, you CAN rebuild those, too.
Batteries are a bit more of a thing, sure. But I break down and rebuild packs all the time. Theres literally 2 in my shop right now in various states of dis/assembly. It can be done. Usually I recycle the old ones, and just like you would get a credit for a 'core charge' for a traditional alternator or starter, I trade mine in. They get processed (chemically/physically) and what can be reused gets reused. Youre not going to try and tell me that repairing a starter or alternator isnt possible, are you? Technically, Ford and Toyota and everyone else will tell you the alternator is a non-serviceable part too. Same with the 12v Lead Acid battery, IAC solenoid, fuel pump, and basically every other individual component. And we rebuild all those, or we trade them in for a 'core charge' so some other guy can rebuild them (like me). If you had any idea how many ECUs I've repaired or modified in my life time so far... And those are sealed up and buried in epoxy usually; definitely NOT intended to be a 'serviceable' part....but still serviced!
Which reminds me, if you cant "fix a PCB or isolation fault".....you need to set down the keyboard and think real hard about what you just said and maybe reconsider projecting your own capabilities and limitations on to other people. And your ability to search YouTube apparently; there's literally thousands of videos that can teach you that stuff. Thats the whole point of a Slate truck - we can each do it 'our way' as much or as little as we are capable of.
