Motor Trend: Slate Talks about the Truck’s Style, Safety, and a Front End You Can Design
New interview with Slate’s head of design, Tisha Johnson, head of brand and marketing, Ben Whitla, and head of PR and communications, Jeff Jablansky.
Slate says it’s on schedule to hit its first customer deliveries toward the end of 2026, with mass production expected in 2027.
Slate Auto Pickup Truck Motor Trend: Slate Talks about the Truck’s Style, Safety, and a Front End You Can Design 1760527092316-ym
Motor Trend interview 14-Oct
"The first thing we did was to get head lamps that are easy to swap out and don’t require an expensive lighting internal program to create them that we’d have to spend a lot of dollars to make."
Again, I ask, then why not just go with $15 Wagner H6006 glass headlamps. Fits perfect with the 1960's manual rollup windows meme.
The vehicle is already inefficient enough I hope they are going with LEDs and not H6006 halogens.
I'm thinking the LED lights Slate is using are going to get packed with wet snow, halogen might be better with their recessed design.
And there are glass globe alternatives with LED in the H6006 form factor. Still less expensive than a custom plastic lense/housing design. That will go opaque in 8 years...
Even HIDs would be good too. As long as the projector lens can support both styles of light emission patterns it should be good.
Usually HID lamps use a shutter to change from low beam to high beam, and they also need a ballast to light the bulb. Both of which make such headlight units very expensive. 120 watts for 10 hours is 1200 watts, which is 2 miles of energy at 2.4kW per mile. Not a big range hit to use halogen bulbs.
2.4kW per mile? At that rate the 55 kWh battery would last 23 miles. 2.8-3.2 miles/kWh is the rate depending on whether you use max or usable battery size. 1.2 kWh would be 3.6 mile range hit using your scenario. Also, aren’t DRL required now so they are going to have to address DRL, low beam and high beam.
Searching for that bulb, I'm finding 6v offroad use bulbs.
Unless that is wrong, and it's a different wagner H6006 you are talking about, the voltage is a problem, and not being certified for on road use is a problem.
What they're using for headlights appear to have LEDs for the light source. In the recent video I can't tell of these are Daytime Running Lights or if the headlights are turned on. I'm guessing the latter because the amber lights are lit.
Slate Auto Pickup Truck Motor Trend: Slate Talks about the Truck’s Style, Safety, and a Front End You Can Design Slate_LED_Headlights
Summit Racing. Typical glass headlamp used in cars for decades.
Slate Auto Pickup Truck Motor Trend: Slate Talks about the Truck’s Style, Safety, and a Front End You Can Design Screenshot_20251015_185528_Chrom
Garbone
Heh, my C10 uses H6024, work just fine and only $9
Typo. Apologies. Same difference. Not a big range hit.
Zorba
Zorba
F
85 300SD, 06 Jeep, 14 Fiat
Glass headlites all the way! Plastic headlites should be outlawed. Oh, there is no such word as "lense"...
OMG one of my rare misspellings! I was going to go with "lenz" at first. ;)
And is a headlite some type of brand name for a headlamp with lower lumens output? Just askin'
Zorba
Zorba
F
Higher. ;)
