Desired Future Slate Models
This is definitely very early to think about, seeing as how we still have very little info on their first model, but Slate has promised a range of vehicles based on the same or similar architecture. I keep seeing articles and videos where people suggest a 4 door SUV, but if you want a mid size 4 door electric SUV, that's basically the entire rest of the american EV market.
What I want is a small hatchback. Round off the front a bit more at the cost of some frunk room, use just a front motor, keep a lot of the same interior parts, use just the small battery configuration so you can shorten the overall length, and something like a twist beam rear axle. It could even look like a 75% scale version of "fastback" version of the SL8. There's a lot of Yaris and Fit owners out there looking for a replacement.
So what would you want to see their next model be?
It almost sounds like you're describing the Rivian R3?
For myself, I'm a fan of what I call a "two door utility runabout". It can come in many form factors, but the length should be 164" to around 174" long. A Kia Soul is the former size. A Ford Bronco Sport (or a Slate) is the latter. I also call these "tall but small". A trucklet in that size (like the Slate) would be super cool.
Alas, it seems only myself and ten other people in the entire USA want a vehicle like this.
I see them making a R.E.V. With a generator in the fronk Space maybe 4 door but unsure about that or a 4x4 version
RedJoker
Ford Transit Connect
If they made an AWD version, I might own two of them. One would be a lowered, enclosed cargo version (which is what I need) and the other a lifted, open 4x4 off-road version (which is what I want). Bonus points if the AWD can tow 2000#.
They have an R3X version that sounds right up your alley. Not sure about cost though. It seems likely to be a $35,000 class vehicle.
The R3X seems like it would be closer to the size of the SL8 fastback, I want something like a foot shorter. (Yaris replacement)
Oakwise
Jonathon
Redlands, CA
Prius C
Agreed! My hope is to by the current Slate, add the fastback cover and NOT the seats.
Call it the CURB and market it as the ultimate city car.
For predictions, I'm pretty uncertain for a lot of reasons.
Thankfully, this is a thread about what I would want, and that's much easier.
The Slate Truck is not especially aerodynamic and its drag coefficient is multiplied by a large frontal area. Drag is undoubtedly a limiting factor for freeway range. That's fine for what it is, and I don't believe the range is insufficient. It's been identified as a "city" vehicle that isn't meant for interstate driving.
However, I like to imagine a vehicle with a sleeker profile that could achieve similar range and better freeway performance (and comfort, I think drag translates to noise?) at a lower weight. A Slate Coupe.
I don't think it needs more power, at least not significantly more. Keep it rear-wheel drive but give it independent rear suspension.
I don't know if the multiple configuration concept/gimmick would work outside of a pickup truck, since the concept of converting a truck to an SUV/van is basically where the concept of an SUV/van started in the first place.
The body styles I'd want to see are a 3-door hatchback /"shooting brake" with 2 or 4/5 seats. Shorter proportions so the 2-seater doesn't leave room for an entire truck bed, maybe. Could have a convertible/open roadster version.
It could be a more efficient freeway commuter, and an affordable electric sports car. The "electric MX-5" internet enthusiasts like to talk about.
It might be possible to make it slightly cheaper compared to the Truck by needing a smaller battery and by having parts commonality.
I imagine that, when making a second model, Slate Auto would have demonstrated profitability and be looking for a way to diversify, expand, and reduce their reliance on outsourcing.
Being established would give them flexibility that isn't available to a stealth team developing a car from scratch, so escaping their original limitations might give them reason to develop a second model after all. Building a bigger and more-integrated factory would also keep to their founding goal of utilizing/expanding US manufacturing. I've wandered too far into speculation though.
I just want to see a Slate Coupe.
I wanted a Jeep J6 concept in the worst way. Except Jeep didn't build it. And if they had, it would have been a Jeep. So I want an open air AWD Slate beach buggy. Removable roof and rear panels. Maybe removable doors. Maybe even cut out a foot of the bed, because it's for fun, not utility.
It'll never happen, but a guy can dream.
