Upgradable battery management and battery chemistry options (future-proof)
memphsi, tn
I would like to see Slate design the battery / charging system hardware and management firmware/software to be configurable (charge rate, voltage and current modulation, algorithms, etc.) designed for expected battery upgrades. Ford and GM have already announced expected breakthroughs with lower cost, lighter weight lithium-manganese-rich (LMR ) battery chemistries due in the next few years. Toyota and others are working on solid-state batteries as well. These new batteries will probably have different (but not too different) requirements for charging limits and monitoring than the default battery from Slate.
I understand the Slate nickel-manganese-cobalt (NMC) battery is designed primarily to meet the requirements for the possible tax credit, and that's fine for the initial release, but what if the system was designed so that 5-10 years from now, the original battery could be pulled out (quick-connects for the cooling lines?), and an entirely different battery put in? One with less weight, more range? A simple change in the firmware via an over-the-air update and the Slate now has longer range!
I suspect this will require a "universal" battery management system that's initially preprogrammed for the 2 original battery options, but with proper design, could have the ability to change it's voltage, current and charging/monitoring parameters to handle larger kwh batteries (not necessarily with faster charging as that would require much larger power electronics, but at least it could provide the longer range and cold weather performance promised with the next-gen batteries).
Slate could get some additional revenue (as well as 3rd party battery suppliers) by providing the DIYers the option to upgrade the battery with e Slate-compatible battery pack (same size, mounting, colling & wiring ports and voltage) and a quick firmware update.
https://www.caranddriver.com/news/a64746843/gm-lmr-battery-cells-future-ev-lower-prices/
https://insideevs.com/news/757802/slate-ev-battery-chemistry-lfp/
JeffVA
Jeff
Roanoke VA
F-150
That would be ideal if they believe this vehicle will have a 2nd or 3rd owner like they state in interviews
If they put a better battery in it now it will have a 2nd and 3rd owner.
How about the the option of a better battery with no tax credit or the current battery with a tax credit
catiare
Gabriel
Miami
Fiat 500e
I think they sell battery kits for old Leafs that increase the range to more miles than the original battery. So I can imagine this would be possible in the future.
GreatLakes
F150 ‘16 supercab longbed! V8
The method I've heard is to buy crashed Leafs that still have an undamaged pack. At least the first ten years of them all had the same physical size, in kWh of 20, 30,40. So range about 75, 115, and 150 miles. Not sure if the newest models at 240 miles are still the same size.
There are several shops scattered across the States that specialize in this process. (one near Portland OR had about 25 upgraded Leafs when I looked). There is some coverage on the process on Youtube, technically a competent DIYer could do it. Perhaps still not cost effective versus just buying a used Leaf with a larger battery (especially with existing used EV credit).
5ohbrad
Brad
Mansfield, Texas
Nissan Frontier
Great post! You beat me to it. It seems battery technology will evolve faster than the platform. In another thread I referenced the way Leaf owners have been able to easily upgrade from 40kwh to 62 kWh packs. With the steady drops in cost per kWh and advancements in battery chemistry, there is real opportunity here. An affordable to operate vehicle that easily adapts with technology instead of growing obsolete.
Another perspective on China’s battery leadership…this one focused on CATL, supplier to Tesla, BMW, and others. Enjoy.
evtruth
PlugLyf
Warsaw, IN
linktr.ee
The BMS would be built into the battery, so I'm not sure "other" batteries would be an issue. I keep telling people this is a "LEGO" or "Right to Repair" truck because it is. Slate is making it SO easy for you to fix and upgrade this truck, it would not surprise me to see them make it so the battery it removable / swappable with a few bolts. At that point we'd just have to wait for third party manufacturers to come to the table.
I really don't think you're going to have issues with the NMC batteries though. I've seen countless 200K+ mile Teslas floating around on their original battery packs with less than 20% degradation.
evtruth
PlugLyf
Warsaw, IN
linktr.ee
article on battery that will be in Slate
https://batteriesnews.com/sk-on-seals-28-bn-battery-deal-with-bezos-backed-us-ev-start-up-slate/
The one fear I have about Slate's future is if after the first 10000 are on the street suddenly there are 4 or 5 that catch on fire. It will get overblown and make big news and could tank sales. Early reputation is everything.
This already happens. People make fun of Teslas ALL the TIME on social media when they catch fire. The only thing you can do is roll your eyes and ignore them because they don't listen to facts. At least three studies have shown that ICEVs are at least 10x more likely to catch on fire than EVs and hybrids are even more likely than ICEVs to catch on fire, but people just say the stats are cooked. They don't want to believe it because they've already made up their minds about EVs...
Well, at least until they get in one, experience it, and then buy one themselves because they love it. :CWL: :CWL: :CWL:
evtruth
PlugLyf
Warsaw, IN
linktr.ee
One could arguably, if they knew what they were doing, purchase one of these packs and swap the cells into a Slate pack. Probably could make an entire business out of it, haha.
Saint Alban
Anton
Queens, NY
Hyundai Kona Electric
I asked Slate if the extended range battery would be something I could add later…
“At this time, the extended range battery is not something that can be added after purchase. Due to the integration of the battery system into the Slate's chassis and electrical architecture, it needs to be selected during the initial build. “
Unfortunately, it sounds like it’s more than a few bolts.
evtruth
PlugLyf
Warsaw, IN
linktr.ee
Will that's a bit of a bummer. Although it does sound like some things are still fluid, so only time will tell.
That's kinda disappointing for those who want to get the cheapest Slate possible and upgrade later. I wonder if that means the factory long range Slate will have a different chassis than the standard Slate to accommodate the bigger battery.
Whitesands
Alamogordo, NM
2011 Dodge Durango
I'm guessing they probably can't due to mixed health cells causing issues. Kinda like using a mix of alkaline and rechargeable AAs.
