Worst-case Scenario Range Estimates for each battery type (my calculations)
JoeUser
Joe
Polestar 2, Mazda b2300
I'm not sure why you have the lower limit at 20%... While it is true that EVs do not like to be stored below 20%, there is no issue with driving them below that number. I have no qualms arriving somewhere with 2% if there is a charger there. And while it is good practice not to leave an NMC battery above 80% if you don't need to, if you need more range there it's totally fine to charge to 100%. Some EVs even until very recently didn't have an option to set a charge limit, they are charged to 100% every day.
There is also some confusion about what 100% actually means. 4.2V is what cell manufacturers calls 'safe' 100%, but the carmaker calls 100% is normally below that number to preserve battery longevity (hence the 'gross capacity' and 'usable capacity' numbers you see sometimes). So academic studies on cell longevity cannot be directly applied to what you see on your screen.
I've been an EV mechanic for a long time, and my advise to people is to not stress about the battery. The OEM has done their homework, they are not going to let you do serious damage. I've seen babied packs fail at 40k, and I've seen uber-driver 100% daily packs just fine at 250k. Every study on EV batteries just shows that they are tougher and more resilient than we expected, and those studies are on old pack designs. New packs are much, much better.
Exactly. There is a lot of 3rd party and self upselling going on with range. Manufacturers build considerations like that 80/20 and just what type of cells they are using into their charge controllers and range estimates. Just as cell phone manufacturers are more recently limiting max charge and adjusting battery level indications for more longevity.
The 80/20 recommendation comes from when you'd have complete control and see where you are relative to the actual MAX charge and truly dead flat. Like if you were putting together a battery system for your house, and building it from cells, and programming the controller by the voltages of the cells.
Now with people worried about range, they end up with hybrids with smaller batteries and a gas tank, and never touch the gas until they decide they need to run the battery down to use the gas so it doesn't go bad. Same with BEVs buy 300+ miles of range, and drive 50 or less a day.
Lynx
Lynx
Alex
Virginia
Honda CR-V Hybrid
The thought process behind having 20% as a lower bound is based on the evidence that depth of discharge affects battery longevity.
Starting at 4:32 to 8:30, this youtube video explains why discharging at an excessive depth is bad for NMC batteries at a chemical level due to NMC electrode particles cracking, and it includes a study showing this result:
Therefore, in an ideal world keeping the battery between 80/20% just reduces the range of discharge to 60% of the overall capacity, which should mean that the battery should theoretically suffer 40% less damage from discharging over time than if you had a constant 100/0% range of discharge, and it would suffer 20% less damage then if you went from 80/0% range of discharge.
For the purpose of my thought experiment, I just picked 80/20% (60% range of discharge) as a general rule-of-thumb for someone who really wants to prolong their battery longevity in a worst-case scenario. But of course everyone's situation is unique and subjective so this could easily be altered for anyone who is fine with a greater depth of discharge.
I've been an EV mechanic for a long time, and my advice to people is to not stress about the battery. The OEM has done their homework; they are not going to let you do serious damage. I've seen babied packs fail at 40k, and I've seen uber-driver 100% daily packs just fine at 250k. Every study on EV batteries just shows that they are tougher and more resilient than we expected, and those studies are on old pack designs. New packs are much, much better.
Good post.
I think some of the perception issue is EPA range estimates tied to state of charge level. Meaning, if the EPA max range is 240 miles at 100% (useable) battery capacity depletion yet manufacturers state in their owner's manual to charge only to 80% and deplete only to 10% (worst case), for road trips that drastically reduces range for those who are contemplating their first EV purchase. Reading internet EV forums for several years now the issue of charging etiquette arises regarding charging past 80% as the charge speed curve significantly drops from 80% to 100%.
More significant is winter range. The EPA gives zero insight as to range relative to ambient temperature. Manufacturers give no information as to real impact of cold weather on both range and recharge speed. As a consumer I think the EPA range estimates should include specific impacts of cold weather operation on both range and recharge speed. It is difficult to ask of buyers considering their first EV purchase to take such a significant financial risk as the purchase of an EV only to discover it does not fit their intended use case. It's fine to think in terms of averages and 50 miles per day when the EV has a theoretical (tested?) range of 240 miles, but such averages are too simplistic in my opinion to make such a significant financial decision.
As a consumer using the Monroney window sticker as part of the purchase decision, my experience with the last seven ICEV I have purchased, all have achieved significantly better fuel consumption results than the numbers predicted from the EPA testing. I believe it is fair to say EV EPA estimates are mostly optimistic for EV range predictions. Add in cold weather operation and the EPA numbers are even more useless.
I think part of the problem with cold weather estimates is it can vary a lot. Vehicle stored in relatively warm garage, and precondition battery and passenger compartment before unplugging, you will go a lot farther than if parked on the street or a driveway in sub-freezing weather and start cold.
Any reasonable "cold weather" test regime to come up with a range can be blown away by driving habits, blasting the heater, etc.
Not to mention: How cold is cold? My cold only rarely gets below freezing anymore, though 30+ years ago we had weeks at a time below freezing occasionally here. For some cold is -40 or lower, in which case of course you are going to precondition, just as with an ICEV you'd use a block heater.
One other thing to note is that if you preheat the cabin before leaving while still plugged in, the range difference is much lower. It's much easier to maintain a cabin's temp than it is to make the big sweeping change when you first get in and try to bring it up to temp. This is why many people are hoping that the Slate's fob will support preheating from the "2X" button.
Count me among those many people. For me it's important for cooling in Summer as well as heating in Winter.
In winter, when leaving for work early, starting up the heat a few minutes before leaving would be great, especially when it gets cold enough for frost, and in the summer, that's when more range than a regular fob would be good, to start up the AC when clocking out of work.
And preheating impacts on range when the owner can't charge at home?
The point being the Moroney sticker doesn't provide range impacts due to cold temperatures BECAUSE low temperature impacts are unpredictable.
Does the EPA include impacts of cold weather for ICE vehicles, or is there an assumed level of understanding? Do they print on the window sticker at what temperature diesel begins to gel? Or again, is there an assumed level of understanding?
People are dumb, but they're not stupid. This is all stuff that is common sense. I'd argue that anyone who is willing to spend tens of thousands of dollars on something with no understanding of the product they're buying is in for a world of hurt, whether it's an EV or not.
Ice vehicles do not lose 30% (in some EV models) efficiency in the winter. Cabin heat is free in ICEV and is not free in EV. In the summer when AC is an energy consumer, the AC system does not drop the ICEV efficiency by 30%. The few percent in efficiency an ICEV may lose in the winter is immaterial because ICEV can be fully refueled in 5 minutes. I have decades worth of MPG tracking for my vehicles, and the data do not show in any of my ICEV a 30% or even less 15%, hell, even 5% efficiency loss. The ICEV Monroney data have an MPG range due to traffic environments (city/highway) not environmental conditions.
And that is my point, someone new to EV buying an electric vehicle for the first time may indeed not understand that the battery chemical reaction (for both consumption and recharging) is adversely affected by ambient temperatures and that cabin heating is a significant energy consumer. Or someone who does understand the impact of temperature on chemical reactions (maybe they remember their high school chemistry classes) there is not easily obtainable information on the severity of the impact on the particular model they are considering buying.
Regarding diesel, the owner's manual discusses low temperature effects on diesel fuel gelling, but again cold temperatures do not adversely affect diesel fuel consumption. While EV owner's manuals may discuss the effects of cold temperatures on range and cabin heating, it is in a general informational point of view rather than specific data from actual testing.
It absolutely does, but that's immaterial.
I think consumers should be as informed as possible, and that information should be readily available. My only qualm with what you're asking for is; how do you measure it? Is it up to the OEM? Is it a generalized standard, like EPA ranges? If so, what does that standard look like? A chart showing temperatures in 5° increments, SOC @ start, and projected range? That is going to be a very messy graph if it includes -20°F to +120°F. What temperature ranges does it include? Down to -20°F? What about terrain? Do we assume flat terrain? Or do we assume positive grade? Negative grade will increase range, so do we show that too? What grades are relevant? Do we show temperatures varying in 5° increments ALONG with grades in 2.5° increments? Do we account for preheated vs non preheated vehicles? How is that information conveyed? For charging, preheated batteries have practically no change in charging speed vs warmer ambient temps. Do we show estimated peak charge rates, or charge rates in 'real time' across the SOC range?
How is this all conveyed on a window sticker that is already the size of an entire window? How do we ensure that all situations for which you (or others) find helpful is accurately conveyed in a way that is clear?
All that I'm trying to say is that consumers should be informed, and that sometimes that means doing research, not just looking at a window sticker. Spending tens of thousands of dollars is (to me, at least) a big deal, and I know that I look at as many factors as possible when making these decisions
EPA develops a test, just like it does for MPG ratings, reports the results in percentage of the EPA range estimate it now publishes. Report it in graphic form as a line graph as is already done for ICEV emissions (CO2 impact) reporting. A note on preheating the cabin reduces (improves) the range loss by X%. It's not difficult.
Terrain makes it even worse. EV manufacturers do not want such data on the window sticker.
Terrain is far worse for ICEVs than EVs. At least with EVs on negative grades, you don't have to worry about brake fade. Plus it recharges your car. MPG tanks on ICEVs going uphill too. Plus you have automatics hunting for gears at awkward RPM ranges. "ICEV manufacturers do not want such data on the window sticker" :CWL:
Every car I've owned since the Morony sticker came into existence has easily beat the EPA MPG ratings. I keep strict fuel records, its not conjecture nor estimation. I literally have about 800,000 miles of data. Lol at your attempt to try and equalize ICEV inefficiencies under cold weather conditions of EV. That is just humorous. Really.
Like it or not, the current administration is highly unlikely to even contemplate expanding any EPA ratings. Putting together a testing regime and ratings would probably take some years, and would probably only be initialized by congressional action, so maybe in 8-10 years or so you might see some kind of cold weather rating. It would probably have to start with lots of communication between upset consumers and their congressmen.
