Composite Plastic Body Panel Care (Cleaning, Protecting, Waxing, Coating)
JeffVA
Jeff
Roanoke VA
F-150
I'm kind of a Detailing Enthusiast and love the clean Slate color, it will match my SUV. How do you care for and protect this composite material? Can I just throw down an old school coat of Carnauba wax or does it need something special? Don't want a vinyl wrap because you'll have to replace it every 3-5 years of left in direct sunlight like I'll have to. Hopefully this composite material has something like a clear coat on it so we can show it some love and shine it up.
JeffVA
Jeff
Roanoke VA
F-150
Ok, just did some research on this Glass-Filled Polypropylene Composite material this thing is made of and how to protect it.
Looks like you can apply a high quality Plastic Ceramic Coating like Gyeon s or Adam's. Best time to apply will be when it's new with proper prep and decontamination (IPA Wipe). Once coated you can maintain it with almost any good Sio2 topper. Don't wait for it to start oxidizing before you coat it.
It's basically the same stuff you would use on your black plastic trim to give it depth, gloss and UV protection which this composite will be prone to. Probably a good idea to coat it yearly.
Hopefully Slate will include proper care instructions for this composite because the unknowing may just try to wax it like a regular car which could be bad.
Is it cheaper to do all this or just replace the wrap every five years (more years for me in Seattle)?
JeffVA
Jeff
Roanoke VA
F-150
Not really because it would be a good idea as well to apply a ceramic coating to a vinyl wrap as well. So coating this "clean Slate" as it may be will be the same without the cost of the vinyl wrap.
Not very expensive stuff and it's DIY. Take a look on YouTube at a coating called Carpro Skin. I'll use a product like this no matter which way I go. It "May" not be a good idea Not to put a vinyl wrap on it. Vinyl will protect the composite so it doesn't age like a plastic lawn chair in the sun. Even a clear film coating my be a good idea if you just like it Clean.
Slate will ensure we have detailed care instructions since nobody currently has experience with composite Body material
JeffVA
Jeff
Roanoke VA
F-150
Take a look at CarPro Skin. It's a ceramic coating for PPF and/or vinyl wrap. Several similar products like this and it's DIY and lasts about 2 years.
Follow that up with a ceramic detail spray on maintenance washes.
OR, if you like the color Clean you should consider a PPF film coating (like clear vinyl) to protect the composite so it doesn't age like a plastic lawn chair left in the sun ☀
You can replace a wrap but replacing panels could get expensive. At a minimum you should coat it with something if you plan on leaving it bare.
BahamaTodd
BahamaTodd
Palm Beach, FL
2004 GMC Canyon
I'd like to do a wrap, but not if it's only going to last a few years. Will this make a wrap last with regular upkeep?
JeffVA
Jeff
Roanoke VA
F-150
If left in the sun you can probably get about 5 years out of it. Go with a light color so it doesn't soak up heat. Coat it, wash it every few weeks and use a spray ceramic topper when you wash it and you'll be fine. If garage kept it could last many many years but I don't have that option
I’m thinking a custom wrap that is primarily white with integrated graphics. Good suggestions from JeffVA on how to protect.
lgerger
Tesla Model Y LR
Anyone know how the gray composite panels (no wrap) will hold up using automatic car washes, given any empirical evidence from other vehicles? And spare me the lectures (;)), I will be using automatic car washes; I'm very busy and don't want to take the time to hand wash my vehicles.
If you live in az I pretty sure you know what the sun does to both wraps and plastic if you don’t know well wraps will crack and be horrible to remove where the glass filled poly will start to deteriorate and well guess fibers in your skin isn’t good so I’d say for the basic coating every 6 month depending on weather would be a good option for just the poly wraps not sure but I bet there is uv protective coatings for that I bet
I might be interested in wrapping my new Slate at some point. Some questions...
1. What is the cost of wrapping a Slate? $500 - DIY. Estimated time: 2-4 hours. Please confirm.
2. What is the cost if you prefer to have it wrapped by Slate? At the Delivery Center (if available)
Just wanted to share the following with the group.
As a point of comparison, consider the following estimate from Tesla:
Cybertruck & Model 3/Y Vinyl Wrap
$4,000 - $4,500
Installation by Tesla: 3-4 business days
Slate Auto Pickup Truck Composite Plastic Body Panel Care (Cleaning, Protecting, Waxing, Coating) 1748819498360-nr
Thanks in advance for your comments.
JeffVA
Jeff
Roanoke VA
F-150
$4,000 - $4,500
I'm sure Slate will have a cost effective installation price. If they say it can be done DIY in several hours I would assume that install price (from Slate) would be around another $500 at most. Slate is saying that it's designed to be wrapped so I can't imagine they wouldn't make it affordable. Your looking at $2-3k at a wrap shop cut to fit but with pre-cut vinyl and no need to remove any trim pieces is huge for cost reduction.
Whitesands
Alamogordo, NM
2011 Dodge Durango
At the launch event they wrapped one in about an hour, and from one video I saw it only took 2 people to do it. So I figure about 2 man-hours to wrap, maybe 3 for someone not used to it.
Apparently Slate Auto isn't expecting owners to have OCD about keeping body panels pristine.
Slate's design philosophy is equally unconventional. The company's head of design, Tisha Johnson, describes the inspiration as a "battle-scarred shark," a motif that embraces visible wear and tear rather than hiding it.
