Double-din radio housing for center dash and dash speaker blanks
Memphis
Remove the center dash cover and snap in a double-din sized sized hole cover with a open cavity behind the dash along with generic metal mounting points. This would allow installation of after market radios, many of which include built in apple car play, AA. Also for left and right, need matching speaker blanks. They should also have a pre wired12v run, acc and ground pigtail stuffed back there.
example…
https://www.crutchfield.com/p_113DMX809S/Kenwood-Excelon-DMX809S.html
JeffVA
Jeff
Roanoke VA
F-150
Completely agree 👍
Boomer here and I leave my phone at home on purpose, it's not an extension of my body.
Hopefully Slate will develop a plug in basic FM radio with a single speaker for the center of the dash. Some pre wiring and antenna would be great. Will remind me of my 70ies era Chevy.
Swinefuzz
San Diego, CA, USA
'98 Jeep Wrangler
enigma9o7
Craig
3000GT VR-4, Ford Explorer
Even something like that would work, but besides the DIN opening and power/ignition wires, we'd still need an antenna. And I'd rather not have to drill into new truck to install that, I really hope if they offer radio-ready option that not only includes somewhere convenient to mount it, but also a 30" mast antenna wired to that location. Somewhere to mount speakers and wiring would be nice and preferred, but I can see how that isn't absolutely necessary with a head unit like the one pictured above... but an antenna still is!
Slate should use the rear window defroster grid for the antenna, like BMW does.
enigma9o7
Craig
I admit I haven't tried BMWs version, but I've used something similar in the past and they are nowhere near as good as a real 30" whip, they're basically only useful for close stations. If you live somewhere 45+ miles away from the city, they hardly work at all. I would prefer they keep it simple with the traditional screw in easy to remove 30" antenna mast on passenger front fender, like full size trucks (and many older cars) use.
That being said, it'd be better than nothing for sure. But why try to do something complicated like that when a simple solution works better. Plus, not everyone has the window right behind them, some people are doing the fastback or SUV version so everyone will have different glass and so would require wiring different, etc, makes it more complicated.
The radio antenna on my E90 worked excellently. The glass transfers to the back of the SUV (kit).
But not the fastback, and transferring to the back of the SUV would mean the cable has to be extended.
Do single cab pickups even have a defroster grid?
But isn't the Slate not just a single cab pickup? Isn't it convertible to an SUV and wouldn't an SUV need a rear defrost grid for the rear glass? My 2-door Bronco has rear defrost on the glass. Also, being an EV in a single cab configuration, wouldn't it be better use of electrical energy to heat the rear glass via electric wires rather than depend on inefficient cabin heating?
Extending the wire harness would be hard? Harder than adding the harnesses for the rollbar airbags and rear seat presence sensors?
Not sure why you guys are pissing all over my (what is BMW's) elegant solution to not needing to add a whip antenna to a plastic-bodied pickup truck. Lol.
So far in the prototypes we've seen, no sight of wires on the window.
I've also thought of the idea that a whip could probably be skipped with plastic body panels, range might be reduced compared to a whip, but an antenna could be placed under the roof panel.
Many vehicles no longer have whips, and instead have fins or stubby whips. With slate, there is no large ground plane, but a flat antenna could occupy up to most of the roof area.
The engineering development models we've seen so far have had mockups of buttons without all the details of the electronics and controls. The main mechanicals appear to be there but not all the details of the electrical architecture, the SUV kit, nor how the rear glass works.
enigma9o7
Craig
I hadn't realized it was all plastic. I'm still learning about this vehicle. And learning about antennas. Perhaps it would be possible to put a few wires in the hood to make a sort of ground plane, to connect to the base of the antenna. But obviously this isn't a simple matter, probably why they decided to skip it.
If in the glass works as well, how bout put it in the front windshield? Like a whip on front fender, that also voids differences for different bed/shell/whatever configuration.
How the rear glass works at all is something that hasn't been on the early prototypes we've seen. The mechanism that it is attached with was also just temporary non final parts in those prototypes.
We used to see wire antennas embedded in windshields, not sure where those went, but it does seem that those and rear window defroster antennas could be at least matched with an antenna hidden under a roof or other panel.
On the other hand, with plastic panels, it would be easy to add a no ground plane whip.
