Slate's open dash panels are ideal for Amateur Radio / GMRS!
Amateur Radio Fans:
Appears that Slate's open dash panel design may be ideally suitable for mounting a mini–Amateur Radio or GMRS mobile rig. This location would be superior to cup holder mounts or under dash brackets. The flip open panel will keep the unit visible and neatly hidden from view when closed. Even with optional speakers, it appears that there is ample room for a GMRS rig or equivalent. It's likely that Slate is already working behind the scenes to add this radio tech option along with antenna mounting options.
Definitely looking forward to this!
Slate Auto Pickup Truck Slate's open dash panels are ideal for Amateur Radio / GMRS! slate dash panel
Love that idea!
I'm a ham - over 45 years licensed since 1980.
BTW, trying to renew my license on line is a PAIN.
I just installed a 2m / Aviation dual band HT w/ Compactenna LMR mag mount on my EV.
Also have a 70cm mobile with 1/4 wave mag mount.
The antennas were a pain as there is not enough metal for a decent ground plane.
New student pilot adding VHF AM (simplex only) is a new concept for me being used to crisp clear FM.
Hoping the FAA will revamp the ancient AM radio comms to more current digital or satellite comms.
Slate Auto Pickup Truck Slate's open dash panels are ideal for Amateur Radio / GMRS! IMG_3650
Slate Auto Pickup Truck Slate's open dash panels are ideal for Amateur Radio / GMRS! IMG_3654.JPG
The plastic body panels,will make antenna mounting interesting
slateya
Minnesota
I am hoping the removable body panels allow for stealth wiring and antenna installation. The open dash with cover looks great already.
Swinefuzz
San Diego, CA, USA
'98 Jeep Wrangler
I was thinking the same thing. A terrestrial radio antenna should also work beneath the plastic fender or wherever, no cutting, no weather, no theft.
Swinefuzz
San Diego, CA, USA
'98 Jeep Wrangler
Not sure, but in this view, it appears the hidden dash panel has a 12V power car plug for ham radios, dashcams, and radar detectors. USB ports would also be nice!
I saw a video that showed USB ports in the compartment directly above the climate control knobs. Also, I think I saw another 12V port in the frunk, which would be a perfect spot for a portable cooler when shopping or camping. And if they're smart, there would be some kind of port presence at the tail end of the bed as well, or at least wiring so someone can DIY their own solution.
As long as your grounded to the frame, you should be golden. I think the removable panels should help with that. And depending on $$$ getting an extra one to poke holes in...I'm thinking a CB whip and fab an adjustable extension to tune it for 17 M. I already have my Yaesu FT-817. Just watch the power draw if using anything that pumps out more watts.
slateya
Minnesota
With the plastic body panels not blockiyRF, I plan on stealth antenna install under body panels.
