- First Name
- Kevin
- Jul 4, 2025
- 5
- 1,344
- 1,570
- California
- Nissan Versa
Exactly. While with slate, it looks like you could add the roof rack and 2 towers, and be able to easily put on some rails and add a good amount of panels, the added weight and drag would probably negate any charging you'd get, unless you are only driving like 5 miles a day, no freeway speed, and always parking in full sun. Even then if you are parking in the same spot every night, better to leave the solar there, either grid tied or charging batteries that you then charge the truck with.A vehicle has to be very efficient to get meaningful range from solar panels that it can fit on it's surface area. The Aptera might be able achieve meaningful range from its panels though I wouldn't be surprised if it falls a little short of the "Up to 40 miles" claim. With 4 wheels, more passengers, and much more weight and less aerodynamics I'd think 10 miles would be pushing it for a Telo or Slate with onboard solar. As long as your EV has a battery there is little need to carry your solar panels and associated electronic components around with you.
