Possible Telematics Module
Preconditioning via the fob is an important feature.
If preconditioning requires a Telematics Module that would be severely disappointing.
Prepare to be disappointed. Slate’s response included a direct reference to a Telematics module, wherein the OP never mentioned anything about it. In my opinion, Jimmy the Slate agent just let the cat out of the bag. Good thing he added, “we’ll know more as we get closer to production.”
I’m not sure that’s the case. They have already specifically said updates will be done via the phone, meaning it won’t have telematics
I wonder how preconditioning with a FOB would work. In Atlanta, I might have had the AC on when I parked the truck yesterday but have woken up to frost on my windows and want to press a button on the fob to defrost the car while I'm getting ready to leave for work. How does it know whether the preconditioning is AC, heat or defrost?
Pretty much all vehicles already account for this, even manual temp controls like the Slate. Just uses interior (basically every vehicle has this but not needed) and exterior temp (almost positive EVERY vehicle has this, absolutely if it’s an ICE vehicle) and adjusts as needed
If it's anything like the remote start in my friend's Plymouth Neon back in the early 00s, it'll all come down to whatever you set the HVAC to prior to getting out of the vehicle.
That being said, I doubt the HVAC controls in the Slate are anything more than digital knobs controlling electric blend doors so it wouldn't be hard to have the Slate's programming set to a 'default' middle between hot/cold w/ AC on whenever precondition / remote start is used. The only thing that complicates that is the heat is a separate on/off button, not just where you set traditional blend doors.
It’s fully digital, so no matter what the setting are, the vehicle has the ability to do literally anything with no relation to the head unit controls. Now once the door opens (or Jeeps terrible design, until you adjust setting) it will go back to the user settings, since then the user is “know inside” the vehicle and “wants control”
This is another thing we won't know yet, my guess would be digital rotary encoders, like often used on car radios now, where the knob spins around and around, no mark on it, and you feel the resistance at each step when you turn it. These knobs basically signal +1 each movement of a certain number of degrees, and -1 when you rotate the other direction. You can't for example turn the volume to max on the radio when it's powered off, it always comes on in the same state it turned off at.
The one issue is the prototypes and renders we have seen do appear to have marks on the knobs that would indicate the absolute position of the knob matters. Maybe that's just because it's preproduction, or maybe preconditioning will ignore the knob position.
The basic radio Jeeps have the absolute position knobs with an indicator, it still ignores it on remote and extremely cold starts
