Bench seating for front
MavStangVa
Banned
Va
2024 Maverick Lariat 2.0 Eco-boost, 2005 Mustang Convertible.
I insist…. The DIY and the basic model to customize… will create a lot of aftermarket manufacturers!!! Sure some bench seat will appear in the meantime.!!
Even two rear seat at the bed side by side . Like old Land Cruiser pickups.!!!
They will research the cost to produce, the cost to sell, and the liability of adding a non-restrained passenger and no air bag and their lawyers will say "pass on that."
MavStangVa
Banned
Va
A bench seat may make me keep the truck configuration rather than going suv. But if they are already doing saftey tests with out the bench I don't think it will happen.
That said the aftermarket may step in. For example:
https://corbeau.com/collections/bench-seats
Notice those are for vehicles that were available with a bench seat and DO NOT add a third passenger seating. In other words they are replacement seats which puts the liability on you for proper seat belts etc.
" The 42" Baja Bench comes standard with vertical tabs on the bottom for mounting to a roll cage. We do not recommend this seat be used in places where a seat was not intended by the original manufacture of the vehicle. "
Ewwgas
1991 Miata
I think it's saying don't mount it in the bed of a pick up. But If they started selling a frame that bolted to the oem seat mounting positions you could bolt that seat in.
MavStangVa
Banned
Va
True but YOU assume all liability for lack of proper seat belts. I think of it this way. If I would let my 3 year old grandchild ride in it unbuckled then it isn't safe. But if you buy one do what you want. That's the beauty of freedom of choice.
Ewwgas
1991 Miata
Not sure I get what you are saying, the post when I brought up that the aftermarket may make a bech seat I posted that company as an example. Obviously those are for some other application.
Make sure you make your grandchild wear a seat belt, I don't know any seat that I would sit in without one. Maybe that audi from i robot.
MavStangVa
Banned
Va
My point is that company sells a bench seat for 3 passengers but does NOT provide the seat belts to go with it. So unless Slate adds seat belts for anon-existent back seat or third front seat passenger there is no safety features. I work with a guy who made a Durango extended cab out of a standard cab. No rear belts! Just because it can be done does not mean it is a good idea.
2018 Tesla Model 3
If bench seats are regulated out, someone should inform Scout.
I just looked at Ford's website and you can still buy a regular cab with bench seat and seating for 3. No front or side airbag for middle seating position. They would have to add a seatbelt. Not sure whether is has to be a shoulder harness or whether lap belt is sufficient. This seems to be a popular voted up change. Hopefully, Slate monitors this forum and takes note.
Someone with more knowledge feel free to correct me, but I think bench seats went away due to safety regulations. So unlikely there would ever be an official part.
If Scout can offer it, Slate can too. The big question is whether they think it is worth the extra tooling/engineering to make it happen.
a bench would be cool and would remind me of my first ever truck, but I also don't see it happening for safety / liability reasons
Dimensionally is there even room to put a third seat in? The Slate is pretty narrow...much narrower than the Scout by 9.3". If yes, I could see Slate offering a bench seat replacement for the two individual seats. It might look a lot like the rear seat(s) for the SUV Kit.
slateya
Minnesota
It is wider than my 1991 Toyota pick up that had a bench seat in the front for three.
2018 Tesla Model 3
They are offering a 3 spot bench in the rear so should be the same width in the front seat. Granted sitting 3 across in a compact truck is much tighter than 3 across in a full size. Definitely wouldn’t want to do it on anything but a short trip.
