From a design point of view, what limits the slate to 1000 pounds towing capacity
is it axles? Battery? motor? etc
Someone posted about the toyota IMV 0/hilux champ concept. It is 12K in 3rd world markets because they have stripped everything. Crank windows, 2 doors, no radio, etc. Very much the same philosophy as the slate.
It mentions things like no ABS makes it easier for upfitters to put a beefier axle in.
When we talk about payload and towing, what is the limiting factor?
I do think people might underestimate the "upfitter" market in the sense that upfitters want a stripped down vehicle that they can build up. vs having to strip it down first.
Middle of the Mid Atlantic
It's a small, lightweight unibody design, is my guess. Brakes on the Munro video seemed pretty beefy, but that is a good guess to. Heck it might just be a range limiting factor.
The slateboard design is not unibody.
I'd not call it a pure EV skateboard either. It's really in my view a spaceframe w/ bolt-on plastic panels design similar to the Fiero. Maybe it should be called a "skateframe"(?). But the point is the Slate design is not a true body-on-frame, which allows for higher towing capacities.
From a towing perspective I look at the frame design as closer to a unibody than a body-on-frame.
Whitesands
Alamogordo, NM
2011 Dodge Durango
Likely frame, since its capped to 1000 like some that used to have bumper hitches. Of course, it could be they haven't tested it since none of the protos have a hitch on them.
My take:
The reason the Truck can only pull 1,000 pounds is because it's an economy car, either in a pickup or an SUV form factor, with as little as 820 pounds of load-carrying capacity.
Economy cars don't pull heavy trailers.
Edit: To put it another way, it's not some specific Truck attribute, it's just the nature of this particular beast, because low price (cost-of-ownership) is a top priority in its design.
My take:
but which parts (design choices) of it limit the towing or payload?
What I'm saying is: Any and all.
Pick your favorite. When making that choice they chose not to increase cost to achieve extra towing capacity.
Edit:
They're Systems Thinkers that determined parameters, including towing capacity, and designed to those parameters.
Bonus feature of that: IMHO abstract parameters like "the experience of owning, driving, and riding in the Truck" were given more-than-usual priority.
Eric Keipper explains what it is in the Rich Rebuilds video.
Yeah, I just can't see another Rich Rebuilds video...
I like "Skateframe"...
The Truck will have a proper frame that runs the length of the vehicle.
Edit: The slateboard's design is unique.
atreis
Eric
SW Ohio
It's a choice, and then Engineering around that choice, so likely not any single component at this point that limits it to 1K lbs.
They decided they would design it to have a target GVWR and GCWR (where the GCWR is 1K greater than the GVWR). Then when the Engineers design the frame, brakes, suspension, etc. they design and select components that meet that spec plus a safety margin.
RedJoker
Ohio
Ford Transit Connect
The issue that I have with the 1000# towing limit is that most single axle utility trailers need 2000# capability. Many unibody vehicles can tow that, so why can't this? I don't think it's unreasonable to expect to be able to get a single scoop of mulch on a utility trailer.
well a single scoop would go in the bed..
