Maybe the reason I'm ICE-cautious is because of a past experience with an unproven new engine design.
My '89 Dodge Raider had a Chrysler 3.0L V6 engine with a valve guide defect that, years into ownership, caused the engine to consume oil.
More importantly, there was a looming possibility of catastrophic engine failure if the engine was left un-repaired.
That sucked.
Well, good thing the Slate's drivetrain is well documented and proven!
Sparkie
Sparkie
Sparkie
Massachusetts
Bronco
My previous car was a 2000 ford focus, had the engine replaced, piston knock, took extra time, once they got the right engine, and got it installed, the computer wouldn't work with it despite getting if flashed by the dealer a few times, so that had to be replaced too, at that point would have been better to have just swapped to the "wrong" engine which was the upgraded option on a new vehicle, because that also would have required the same computer work. Then a couple years later that base engine had the valve seat problem, repairable without replacing the whole engine at least, but a known issue with that engine. A while later I started looking at what vehicles were supposed to have lowest total cost of ownership, because with the mileage, either I was going to have more valve seats fail, or transmission fail or something eventually.
Yikes!
Rust was the biggest problem I had -- but that's a problem for all cars in New England.
B1050
Ben
Lafayette Indiana
Ram, Outback
Slate would probably have to buy an ICE engine from another manufacturer because the machining tools needed to make a gas engine would be very expensive. That being said I'd vote for a Subaru 2.5 engine. I think startups from here on out will either buy engine/trans from known suppliers or be EV.
The e-motor isn't built in house, so we can look at the reliability, right? The JJE SD180 looks to have been used in commercial fleets of EV vans. Outside of the e-motor, there's halfshafts and u-joints. Not much complexity there. The gearbox is built into the drive unit, there's no intermediary driveshaft or carrier bearing, no transmission, etc.
I think that is obvious (other than selecting a crap-ass Subie 4-cylinder). But why would any new automotive producer startup as an ICEV manufacturer in this day and age, other than as a boutique offering? There is zero business case for it.
It will have a differential.
Having owned both, I'll never go back to ICE. I have two remaining ICE vehicles: My RV, and the car that I pull behind my RV. I'm hoping the Slate will replace the car (assuming their plan to make it flat-towable comes to fruition). Someday I'm sure something will come along for the RV, and I'll be right there waiting. I replaced my ICE boat motor with an all-electric setup using an Elco motor and 19kWh of battery capacity this past summer.
Do the marina's charge more for electrons because it's charged on the water? :CWL:
Doug T
Doug
2024 Ioniq 5
Monro & Associates has done many breakdowns of EDUs from Tesla and other OEMs. Given their relationship with Slate, I have to believe that the JJE EDM has been thoroughly vetted. Perhaps even improved if necessary.
I am in on the Slate purely for the small pickup concept. It could run on kerosene and I'd still be interested.
In regards to the ICE engines, I'm really hoping the Slate takes off, because with the price point, I fully expect it to become a test-bed for some vanity projects. I'm sure within a year someone will graft in an ICE engine over the top of the de-dion axel like a modern day Corvair van. Intreped YouTubers already proven a Harbor Freight Predator motor will power a car, and I've seen someone snowmobile engine swap an RX7, I bet someone could shoehorn a little ICE engine into the rear of the Slate.
...with something like 25 moving parts instead of 2,000.
I mean.... sure?
Not really sure how that is relevant. Something moving doesn't equate to something breaking. The battery doesn't "move" - but there are hundreds of points of failure on it.
I mean.... sure?
Movement causes friction, which causes wear. I don't think anyone needs to pretend like that isn't a thing.
I mean.... sure?
Oh, now you've done it! :CWL:
