Plan Slate road trips with ABRP
YDR37
If you already own an EV, you are probably familiar with A Better Route Planner, commonly known as ABRP. It's an online utility that allows EV owners to plan road trips, with recommendations for charging stops and charging times. ABRP is owned by Rivian, but it can be used for all brands of EVs.
I think some people have already noticed this, but if you weren't aware, ABRP now supports Slate -- both the standard and extended range versions, and including the pickup, SUV, and fastback configurations. Of course, Slates are not actually available at this time, so the Slate settings are just educated guesses on ABRP's part; the settings are designated as preliminary ("alpha"). But ABRP has been doing this for a while, and should be able to make a decent guess.
So if you're curious, you can see how a Slate might fare on a long road trip of your choosing..
YDR37
For example, I picked two completely random locations -- Fenway Park in Boston and Wrigley Field in Chicago -- and got the following results, assuming a Slate pickup leaving Boston with 90% charge, traveling via Pennsylvania, and arriving in Chicago with 10% charge:
Standard Range (150 mile) Battery:
- 16 h 1 m driving: 9 segments, averaging 111.1 miles each
- 2 h 59 m charging: 8 charging stops, averaging 22.4 minutes each
- 33 m to get to/from the 8 charging locations, averaging 4.1 minutes per stop
- total time of 19 h 35 m for 1000 miles
Extended Range (240 mile) Battery:
- 15 h 55 m driving: 7 segments, averaging 142.4 miles each
- 2 h 35 m charging: 6 charging stops, averaging 25.8 minutes each
- 23 m to get to/from the 6 charging locations, averaging 3.8 minutes per stop
- total time of 18 h 54 m for 997 miles
The Extended Range battery should be helpful on road trips, but perhaps not as much as you might expect. The larger battery means fewer charging stops, but it also takes longer to recharge at each stop.
Garbone
Just to add visuals. 2 trips to visit USS Laffey, One small battery the other large. I find ABRP to be very accurate in its estimates and use it for trip planning.
Slate Auto Pickup Truck Plan Slate road trips with ABRP Screenshot 2025-09-17 6.18.12 AM
Slate Auto Pickup Truck Plan Slate road trips with ABRP Screenshot 2025-09-17 6.16.09 AM
This is my settings, Using Tesla with Adapter, Avoiding AE at all cost. The only stops I would change are the ones in Florida, I try to use FPL chargers as they are 30% cheaper per KW. This means I would be hitting Yulee Fl with the big battery and the FPL charger south of Jax with the small.
Of note: My Standard range MachE plugged into this trip is within 1 minute of the large battery estimates. I find this acceptable.
May as well check out the Yorktown while you're there!
Garbone
Not to mention the Boat trip out to Ft Sumpter.
Slate Auto Pickup Truck Plan Slate road trips with ABRP IMG_20250831_165251671
Slate Auto Pickup Truck Plan Slate road trips with ABRP IMG_20250831_153819371
Slate Auto Pickup Truck Plan Slate road trips with ABRP IMG_20250831_160616796
on the east cost it might not be that different, but try austin, tx to Balmorhea state park.
YDR37
I tried it with a Standard Range Slate, and it worked -- but only if I specified that I had a CCS adapter. Without the adapter, I got "no valid plan found".
With an Extended Range Slate, the trip was possible without the CCS adapter.
but take a look at the dramatically increased time because you have to go out of your way.
11 hours vs 8 hours. 8 hours of driving time instead of 6 hours.
In the extended range you can do it in 7 hours with 6 hours of drive time.
So in a gas car you can do the trip in about 6 hours, in a slate 7-11 hours.
On the east coast this wouldnt be a problem because of the density of population centers with chargers
YDR37
but take a look at the dramatically increased time because you have to go out of your way. ... On the east coast this wouldnt be a problem because of the density of population centers with chargers
No argument here. If you are going to drive an EV pickup in sparsely populated areas with few chargers, then yes, you want an EV with a large battery for maximum range.
If you were going to drive a traditional F-150 in remote areas with few gas stations, you would probably want the 36-gallon gas tank for maximum range too. Same concept.
For those who like to be spontaneous and not tethered to ABRP, new signs are rolling out on major highways! And since Slate offers the NACS charging port, you will be greeted with the following:
Slate Auto Pickup Truck Plan Slate road trips with ABRP 1759069385582-ft
