SUV vs Open Air Kit
jcash757
Jeff
Louisville, KY
2017 Subaru Outback
Does the SUV have the same roll bar that the Open Air Kit has?
jcash757
Jeff
Louisville, KY
2017 Subaru Outback
Thanks. I thought I could see it in the photos.
Remember, Slate philosophy is multiple uses same part
That's probably a borrowed Munro Associates motto. It likely follows "the best part is no part". Which goes along with "fasteners always fail". Sandy Munro's crew is an endless source of pithy aphorisms.
D'Mick
Miguel
New Jersy
2018 VW Tiguan, 2025 Tesla Y LR
There's no open air kit. Both kits are open air once you remove the top.
jcash757
Jeff
Louisville, KY
2017 Subaru Outback
I was going by what the Slate website says. They call it the Open Air Kit
Slate Auto Pickup Truck SUV vs Open Air Kit Screenshot 2026-06-11 at 14.56.05
I can see why that could be different, perhaps cheaper than the SUV and just remove top and windows, assuming windows are removeable.
Imhotep
2008 Prius, 1974 GMC K1500
In a roundabout way, I think they’re saying it’s the same rollbar. We’re all guessing here, but I think the suggestion is that you buy one of the SUV kits and take the top off to achieve open air kit. Same line of thinking as the no doors configuration doesn’t mean you get a truck without doors, you can just take them off.
Again, just guessing here.
jcash757
Jeff
Louisville, KY
2017 Subaru Outback
I could see buying the "Open Air Kit", being a huge savings since it would come without the top.
Shrink36s
'18 Equinox
... Same line of thinking as the no doors configuration doesn’t mean you get a truck without doors, you can just take them off.
Or, does it? It's probably a wee cheaper without the doors! Money saved!
Also, I do believe someone asked Slate and reported back here somewhere that the roll cage is what is under the SUV kits, and that, indeed, the open air is simply those kits without the topper. This would save you money if all you wanted was truck and open air kit for funsies. That would save you, I imagine, at least a couple/few hundo.
You can see on interior pictures of the SUV kits that the same roll cage is shared between the 3 builds, SUV, fastback, and open air. It appears that if you are building one of the SUV kits, at a midpoint in the build you basically have the open air built, then you bolt the lightweight panels and roof to the bars. So it seems those bars are structural for the SUVs, not sure how the cargo kit works, easiest way they might have done it is with a thinner frame that goes in that doesn't have the airbags, just to hold the structure together.
