What's the Slate's maintenance like?
But the BMW N52 is well known for its longevity. 300,000 miles is the rule.
Let's be clear here though. Sure plenty of engines are capable of achieving unnecessarily (from a manufacturer perspective) high mileage... But all of that moving part longevity comes at a not insubstantial lifetime preventative maintenance cost.
BMW has some of the neediest engines I've experienced from a preventative maintenance standpoint. Beyond the typical (many) oil/filter changes and whatnot, never before owning an N52 did I have ANY engine need an 'oil filter housing' (dumb non-integrated design) gasket, valve cover gasket, and oil pan gasket replaced every 100k or so. I'm not sure why, but they couldn't engineer a gasket rubber to save their lives, despite other manufacturers having figured it out decades ago. Same with the ~100k limited-life electric water pump and thermostat. The whole ownership experience was best summed up by 'so close, yet so far'.
I mean, Subaru fanbois can brag that their EJ25 has 300k longevity too... It just needs to be fed a steady diet of head gaskets. :CWL:
JoeUser
Joe
Polestar 2, Mazda b2300
As a former Tesla master technician, I would compare the Slate to a 2018-2020 model 3 in terms of complexity.
Tires and cabin filters should be the only maintenance items for the first 100k.
In theory, brake fluid, gearbox oil and coolant should be replaced at around that mark... In practice it's not critical. The dirty, extremely hot combustion engine and increased brake usage just wear those fluids out in a combustion vehicle. An EV is just much less demanding and the temperature/usage is so much lighter.
Brakes: I saw exactly one model 3 that had actually worn out it's brake pads and required replacement. One. The entire shop came and took a look it was so rare. Anyone who says BRAKES wear out faster on an EV are just dead wrong. In normal driving (non-salted roads) the brake pads can outlast the car.
Suspension is the same as any vehicle. Eventually it all wears out and requires replacement.
That said, new company, new vehicle. There will be failure points and design flaws. I wouldn't consider that 'maintenance' exactly, but it could end up requiring that. Time will tell.
That's encouraging to know. Thanks.
Decades ago a "first year car" was presumed to have flaws. Everyone expected that.
Even farther back (say, 1960's and before), virtually all new cars , first-year model or not, were presumed to require a few trips back to the dealer to have some deficiencies rubbed out.
Flash forward to today and we have high expectations.
Here's hoping Slate Auto can achieve a high Quality Score from the get-go.
Slate Auto Pickup Truck What's the Slate's maintenance like? Almost_Perfect_10
OldGoat
Chuck
Mustang Mach E, Honda Odyssey
Joe! Way to cut through the fog here. Can't help but ask you questions I've had for a few years. When E-bikes came out the motors and controls were all over the map with many crappy suppliers and assemblers jumping into the market. Most bike shops simply wouldn't allow any E-Bike service on anything they didn't sell. Not entirely because of fire concerns which is what they told the owners on junk bought over the internet. It had a lot to do with a total lack of repair parts and serviceability. Will EV's of various brands begin using the same suppliers for their E-systems so independent mechanics can do cost effective repairs at some point? And will there be enough service for EV independent garages to begin popping up in larger markets? How do you see EV service playing out in the coming years? Any hope of plug-n-play battery replacements?
With E-bikes, there are about 5 proven drive suppliers who sell to a wide range of bike brands. And about the same for disc brakes that will safely stop a heavy E-bike. That allows a shop of brand A to service brand B since it might have the same Bosch or BaFang drive as his brand A. Now that he's got brand B customer in the door, he can sell him unlimited accessories and even service "packages".
Okay, then I'll go with 256,000, or 230,000, or 200,000. All "never" in my book. It's not luck, it's good engineering and proper maintenance. The 200,000 miler is in it's 28th year of service. The 256,000 one was 18 years old when I sold it, the 230,000 one was 13 years old. I'm just saying ICEV have a very good track record despite the massive amount of "moving parts".
I won't pretend like ICE engines and transmissions are just waiting to explode, but let's not pretend like they're just happy as can be for all 200K, 230K, 256K, or whatever miles. In that time you WILL have had to do spark plugs, coils, valve cover seals, timing belt/chain, cam seals, etc. At 400K, I would assume your rear main has been seeping for the last 100K miles. If it's an automatic, the clutch pack is probably about shot, if it hasn't been rebuilt already. If it's a CVT, there's no way it lasted to 400K in the first place! haha
My Silverado is a trooper. Been going great since '05. But dear god don't look at the under carriage covered in oil from the numerous leaks. And the LS engine is ALSO known for fantastic longevity, especially the ones without Displacement on Demand, like mine.
Don't get me started on the Subarus I've owned. Head gaskets every 100K miles, Duty C solenoids causing hard shifting and slipping, etc.
You can find all the details about my 400K E90 on the E90Post Forum if you'd like to read about it. Starting at 200,000, 300,000 and finally at 400,000 I documented the car's maintenance and repair history, so I'm not going to rehash all of the history here. In May 2025 the car got caught in a flood event, which made it not economical for me to repair it. The final mileage was 426,843 miles. And I drove the ever living piss out of the car for the 19 years I owned it.
But to address your assumptions. Both the front and rear crank seals were original at 426K and leak free. I replaced the clutch at 293,340 miles. I did not replace the rear seal because several professional mechanics have told me if the seal is not leaking to leave it alone because there is a 50/50 chance the new seal will leak. I replaced the spark plugs at 100,000 mile intervals (one replacement was at 95,000). I replaced the rack of coils once when just one (cylinder 5) died at 287,685. I replaced the valve cover gasket once (305,020) and the oil pan gasket once (293,550). Cam drive (chain) and seals were all original, I never touched them. In fact, the N52 has a very sophisticated valve train because it uses both BMWs VANOS system and Valvetronic system. Each continuously adjust the camshafts for timing, valve lift and lift dwell. The Valvetronic system eliminates the throttle body, the N52 is throttled completely by adjustment of the intake cam valve lift and dwell. The serpentine belt I changed at 100,000-mile intervals. So, all your assumptions are incorrect.
BFD, the N52 has leaky gaskets, so do most engines eventually. My N52 started to leak oil well past 200,000 miles. Most people don't keep their cars 200,000 miles. BTW, I have a second BMW with an N52 and at 17 years and 122,000 miles the trifecta of N52 leaks have not appeared.
I'll point to the European Tesla 2014 Model S that reportedly has been driven 1.2M miles. It has had fourteen (14) motor replacements and four (4) battery replacements. The manual transmission in my E90 went 426,000 miles on 100,000 mile oil changes. Its just good engineering.
Hey, maybe your E90 and the N52 is better than my old E36 3 series and my Z3. Both had to have rebuilt engines around 150K & 160K, and the E36s were notorious for troublesome VANOS.
Please don't take my comments as an attack on you, BMW, or anything else. I'm just saying let's not pretend like those miles are all maintenance free and trouble free, because they're simply not.
As for that Model S, I agree. Those early Model S's were known to develop coolant leaks internal of the traction motor which would cause premature failure. Similarly, E46s are known to develop subframe cracks. And Gen IV Chevy engines are known to have Displacement on Demand issues (specifically with the DoD lifters).
Now, back on topic: MECHANICALLY, the Slate appears to be really simple. ASSUMING the motor is properly cooled, and that the battery is properly heated & cooled, there's not much that can go wrong. The motor is brushless, the steering rack is electronic, etc. It SHOULD be a relatively trouble and maintenance free platform, outside of standard suspension wear components.
I never said the ICEV miles were maintenance free. I originally commented that more moving parts doesn't necessarily mean less reliability. The actual moving (rotating) parts of an ICEV drivetrain rarely fail when the vehicle is correctly maintained. Lots of people jumped on my case about that statement, bringing in manufacturing defects and such - LOL.
I can't speak to your BMW experiences, but I've had 5 BMWs from the E30 to the E90. I have a Z3 1.9L (M44) that's the 200,000 mile car, and my Z4 is basically an E46. I owned an E46 330i Cabrio for about 30-months, which I brought off a friend at the 100,000 mile mark. I drove it to 135,000 miles, it had a similar maintenace history as any of my other BMWs that I bought new (or used, the Z4 at 23,000 miles).
I agree with you. On paper the Slate should be relatively maintenance free. It all depends on how good the engineering is. I look forward to buying mine. But I've never really had a bad experience owning an ICEV. EV do run at lower operating temperatures, about 90 deg. F less from my research, that doesn't mean ICEV are not engineered to run at 220+ deg. F. I know I'll be dead long before my Slate will run out of miles and heat cycles.
I have such a sweet spot for Z3s. I've had a 96 Z3 with the 1.9L, and my brother owned an '00 with the 2.8L. Mine was manual, his automatic. Both were truly awesome cars, and I miss mine ALL the time. I'd own another one in a heartbeat.
I never said the ICEV miles were maintenance free. I originally commented that more moving parts doesn't necessarily mean less reliability. The actual moving (rotating) parts of an ICEV drivetrain rarely fail when the vehicle is correctly maintained. [...]
This is thread's topic is "What's the Slate's maintenance like?".
Consider starting another thread for discussing BMWs and ICEV Longevity in FORUMS > MISCELLANEOUS > Other Vehicles.
I was discussing moving parts and reliability [...]
We can read for comprehension.
Find somewhere else to discuss ICEV Moving Parts and reliability.
Edit: Not trying to be harsh, it's just frustrating. People are going to search for information about Slate Truck maintenance and then find paragraph after paragraph regarding your opinions about how ICEVs can be reliable if well-maintained. We get it! And they're valid opinions! They're just off-topic for this thread.
Just like a few years ago when the internet tried to say fewer moving parts in an EV make them less costly to build vs. ICEV. LOL.
Yes. OFF TOPIC just like that.
Please. I beg of you. Let it go.
But I didn't bring it up today. Why did you?
Because I want the thread to stay on topic and be helpful for someone who's looking for the answer to "What's the Slate's maintenance like?"
Oh. Well, then. If YOU want it to... :rolleyes:
Regardless of what you want, others may find value otherwise. It is a public forum after all.
Information about Slate truck maintenance" does not yet exist to find. The best anybody is going to get is some generalities about EV maintenance mixed with rampant speculation, which was already pretty well covered on the first page. So what does it really matter, if the conversation has gone a bit off-topic 5 pages of rehashing the same old circumstantial arguments later?
Slate Auto Pickup Truck What's the Slate's maintenance like? 299x223px-ll-52e196e1_lighten_up_francis
Ironically, this thread wouldn't have gone so far off-topic if not for your posts trying to keep it on-topic.
JoeUser
Joe
The standardization of components, like the the ebike industry has done, is not going to happen. Bicycles are relatively modular and of similar size/component location. Vehicles have wildly different packaging needs, voltages, communication interfaces, etc...
The difficulty in third-party repairs on an EV has very little to do with it being an EV. It has to do with the industry shift to software-defined-vehicles, of which EVs happen to the vanguard. Bicycles are not generally 'software defined'.
Independent shops already do exist for EVs, but are rare, and specialize in the low-volume EVs of the 2010s. The reason is that the vast majority of all EVs have been sold in the last few years and still have active warranties, and owners who can afford to pay dealer rates.
The number of independent EV shops will grow rapidly as more EVs come off warranty/transition to second owners.
And back on topic, Slate should be a different case, due both to the company 'DIY' ethos, and the extremely limited feature set. I once spent 8 hours trying to solve a Model X 'Holiday Party Light Show' functionality, involving syslogs, CAN graphs, sensor readouts... The blank slate will never have that problem, because that feature doesn't exist. Perfect.
While I agree with this as far as EVs in general, I'm hopeful that Slate sticks with Standardized parts across their future lineup.
Such a 2027 Slate Truck has the same wheel hub, shocks, headlights, ect. as the 2037 Slate (fill in the blank). Or at the very least have them be compatible, so you can put the 2037 brakes on a 2027 as an upgrade.
Looking at what they've done so far, I think they will, but all it takes is a change in leadership and all that could go out the window.
Let’s hope Right to Repair is the rule, not the exception.
