- First Name
- PJ
- Apr 26, 2025
- 12
- 376
- 604
- Atlanta, GA
- 2026 Tesla Model Y Premium, 2018 Tesla Model 3 LR
Drew on the Tailosive EV YouTube channel bought a used Model Y and several months in to ownership that battery wouldn't accept a charge. The battery was replaced under warranty and it took 6 hours in the shop. I think when Slate's battery pack get's to end of life there will be attractive options to replace. Heck by that time there will probably be solid state batteries, 3 times the capacity in the same form factor. If at that point you don't want to spring for the battery upgrade you could always sell the Slate at that point to someone that needs a small truck with 80-90 miles range. I think long term repairability is always an option though you run in to a situation were cost of repair might exceed the value of the vehicle so only makes sense if you intend to keep the vehicle to get your money's worth out of the repair. I imagine if your Tacoma has an automatic transmission that cost of repair if that fails would likely exceed the value of the truck.I wholeheartedly believe in the reliability of a simple EV VS a gasoline powered vehicle.
That said, I am starting to ponder long term repairability. As I see it in the long term, my 2006 Tacoma should be repairable for the rest of eternity, but once the battery pack on my Slate goes dead, is it now a disposable vehicle?
I'm starting to doubt buying decision. Change my mind.
