EVs are more reliable than ICEVs..... GO!
Which vehicle architecture is more reliable/better?
    39
atreis
I think they have a system in China where certain EVs can pull into a kiosk thing and get an automated battery replacement as you wait.
They do, and it's available in some parts of Europe too (Nio is the brand). However, the battery is rented rather than owned, and it's expensive. 169 Euro per month to rent the 75 kWh battery ($200/month), or 289 Euro per month to rent the 100 kWh battery ($335/month).
Interesting. I wondered who owned all the batteries. Even if the vehicle owner owned 1 battery, someone would have to own the pool of spares so that there could be a freshly charged battery to swap in to your car. I suspect this set-up had a lot more appeal when DC fast charging was 50 kWh. Now that the slower DC fast charging stations are 250 kWh I suspect faster trip times would be had with cars that have to be charged versus cars that had battery swaps. You would only have a 100 second swap in the case of no line.
$335 is around 3,300 miles in a 30 MPG ICEV.
My primary point is that when an EV battery pack goes dead the vehicle becomes a 3000 lb. paperweight.
Change my mind.
Battery packs are rebuildable/replaceable. "Non-serviceable" and language to that ilk are only there to say its not easy for the average consumer or cost efficient for the original company that makes the product. Or its designed in such a way as to discourage servicing. How do I know? Because I can build/rebuild them. Its just chemistry and electrical circuits, not magic.
Car ECUs are considered "non serviceable" too and I just rebuilt and re-flashed one last night.
The repairability question also comes with the lack of software support once manufactures discontinue support of a model. As we all know, EVs are primarily software driven where as older ICE are less reliant on that. It's not like you need to update the ECU to keep the engine running well.
Not so true. That ECU I just rebuilt was from my 2008 Corolla and they released an updated ROM image for the 1ZZ-FE motor to address the running and shifting issues they developed as the miles racked up. Ive got a similar story for my Mercedes and BMW vehicles (those get fairly regular updates). Since cars got brains they've been getting updates to improve their performance. Ask any VW/Audi Diesel owner about software if you want to open a can of worms.
That gives me hope. Can the Slate battery actually be removed? I thought it was an integral part of the chassis.
Ducati regularly uses the engine as an "integral part of the chassis [frame]" and its still "replaceable"; you just remove the rest of the motorcycle from it and then work on it.
I've swapped entire truck frames out from under bodies and Id say an entire frame is an "integral part of the chassis".... but that gets done all the time.
That's not something that happens frequently especially on older engines. I would wager 99% of ICE cars from the the beginning of EFI will not receive OEM updates to the ECU. Modern cars sure with OTA updates until the manufacturer decides to pull the plug. My E53 is at peak M54 with its current ECU code and it's never going to receive any updates from BMW.
I voted BEV, because ultimately fewer components will trend toward higher reliability. Electric motors are very mature pieces of equipment, and batteries are too - we've been building batteries of this type at scale for 15+ years now. Sure, their weight and capacity could be better, and are getting better, but we know how to build them.
I think the tough part comes down to what you really mean by reliability? Time between failures? Severity of failures? Time to repair? Cost to repair?
An EV will tend to have a lot fewer failures, but when those failures happen, the time and cost to repair them will be higher. The severity may be higher as well, since there are fewer "marginal" operating states that the vehicle can be in. Electric equipment tends to either work or not work - an ICE engine (particularly an older one) can be running like shit, but still get you home.
Compare my Tacoma (250k miles), with a hypothetical simple EV truck. The Tacoma has been incredibly reliable by typical metrics. However, to get there, it has had a few clutches, a few timing belts, many oil and coolant changes, many air filters, gear oil changes, a power steering pump, etc. The hypothetical EV would have had maybe one coolant change and one gear oil change in that entire time.
On the other hand, the most expensive thing that could fail on the Tacoma is probably the transmission, which might cost $3500 to have swapped with a reman unit. The most expensive thing that could fail on the EV truck would be the battery, which would cost $10,000+ to replace.
So who wins? Fail frequently, but cheaply and easily to resolve? Or fail infrequently, but with very high cost? My money is still on BEV long term, but "reliability" isn't a single dimensional metric.
Back in the day, remember that feeling after you tested out your ICE vehicle after a full tune-up? Restored power, smoothness, and acceleration? Your BEV will never lose that feeling, the smoothness and power delivery will still be there in 10 years as it was on day one.
You left out an important one: likelihood of a breakdown that needs roadside assistance.
Recent large studies have shown that recent-model ICEVs are more than twice as likely to break down and need roadside assistance compared to EVs.
Fortunately the battery will be covered under warranty for at least 8 years and 100,000 miles.
True! Not trying to spread FUD on battery costs, I was thinking about the 250k mile state - what are the risks of a Slate at 250k making it to 300k vs. a Tacoma at 250k making it to 300k. I am hopeful that battery prices will continue to drop (long term - a bit bumpy right now due to tariffs and fluctuating global demand), and that secondary markets start to appear for more remanufactured batteries. Both would help reduce the cost of the battery replacement.
I think we'll see more and more independent shops replacing cells and overhauling packs, similar to how most places around now can swing an engine in an '05 Taco. Typically only one (or a couple) of cells in the pack fail, so there's no real need to replace the entire (expensive) pack. There are a number of shops down in CA that do this already, and as EVs become the norm, I believe they will continue to propagate.
IMHO 9+ years from now replacement battery choices for a 250k-mile 2027 Slate Truck will be available that are reasonably priced, higher performing, or both.
Perhaps, but perhaps not. We've seen the market improve a bit since Tesla initially released ($25k initially for a new battery, down to $10k-ish now), but it seems to be flattening. I don't think we will see sub $5k battery replacements in the near future, maybe 8k or so.
Before labor of course.
Ironically, the biggest source of problems on my ICEV was the tiny cheap battery it came with.
Caused me problems for far too long before I actually replaced the thing.
I consider it inevitable that the ICE powertrain will cause problems/expenses as it ages, and I definitely believe BEVs are more reliable.
