Simple low-tech audio ideas
Come on guys, think waaaaay outside your boxes! Stop reading the warning labels on stuff and just think raw materials.
Easy/cheap - computer speakers and whatever audio source you have handy. Old phones are perfect as a source. Either run a small inverter or use a device called a DC-DC buc converter to get the right voltage to run them if there isnt a proper source already. Just watch your max amperages. The stuff I can cobble together after a trip to the local Goodwill/thrift store would apparently blow your minds.
Normal/good - hit up Crutchfield and write a check and burn a weekend or just take it to your local car audio shop and write a bigger check.
Exotic/Fun - use professional audio gear carefully sourced and spec'd or go all vintage. Me, I'm going the absolute bonkers route and blowing my windshield out again. I like being able to host my own beach party if I want to, complete with free standing stadium cabinets! And this time maybe I won't have to install extra batteries!
Also, and I hate to break it to you fellas, but tapes are digital, too. So is basically every modern processor and amp. So even if you run an analog source, the audio equipment down line from it converts it to digital. If youre worried about compression, bit rates, etc, you're going to need a record player and some very very old or very very specific equipment. I've got some, but I could trade it for the whole truck, so.....
Also also, Bluetooth did only support two audio channels for traditional stereo audio, though the newer Bluetooth 5.2+ LE Audio standard can support multiple synchronous channels for advanced features like surround sound. Thats (part of) why the old BT speakers were usually only mono or stereo. It was intended for headphones and we only have 2 ears to feed. I say "usually" because there are/were proprietary versions some companies did but that made them not compatible outside those setups. The oldest BT 1 standard may have been mono only now that I think of it.
Hey all. This is a great thread, not because some of you want to reuse antique sound equipment but because this is what Slate is all about! Customize it the way YOU want. I can't wait to meet up with other Slate owners to see how they modded their rig.
Keep those ideas coming.
The concept is great, as a "boomer" I remember my buddies buying junkers to "hot rod" as both driving options and as their auto mechanics class project. (Then GTO happened and you could get it that way off the showroom floor, nice but not fun.) Slate will fit perfectly with my pre-1900 farm house...curb look is quant and very old school, inside it has rotary dial phone, cabinet 1950s TV, all works, but look inside and it's all high tech = solar generator, starlink internet, WiFi and Bluetooth running the gadgets, satellite dishes, and short wave radios. The Slate will fit right in with a pushbutton radio and two tone wrap it'll look and sound like a refugee from the 50s. 2 hours of Wolfman Jack, and more. The future will live again!
If it works in a SxS, does the closed cab of the Slate make that big of a difference for sound quality. My guess is yes from what seem to be informed opinions above. It will automatically connect and power up once power is on. No manual involvement.
Would make for an easy sound system. I am looking for good sound quality to listen to my tunes as I commute to work. LOL.
9:40 mark for sound in below video. Don't care for the lights.
I have been using my tricked out golf cart as a test bed for the Slate, wife thinks I'm nuts, but sane people don't have this much fun.
HTXSlate
HC
Houston Texas
And what has your research yielded as far as results?
I actually have a set of these speakers, and they still work. Those long-throw woofers deliver deep bass, as if coming from a much larger speaker. Man I miss Radio Shack, along with Lafayette 🙂.
I do hope Crutchfield will be adding Slate to its portfolio of custom audio kits for Slate. Step by step instructions and phone support if needed. Lord knows I’ve done countless audio installs back in the day.
Slate Auto Pickup Truck Simple low-tech audio ideas IMG_2455
New England
An unboosted 13.5 Volt amplifier will do about 16 Watts per channel into 8-Ohm speakers. That should be plenty for a small cab.
I'll get an amp with an internal boost supply if I need more.
One crazy idea; Replace the seats with seats from a Pontiac Fiero...the speakers were in the headrest.
That was an option, not standard. You can also get those in headrests for.....rear seats on motorcycles as I recall.
Edit: I recently saw them integrated into modern "Gamer" chairs modelled after what I assume were Recarro racing seats. Now wouldn't THAT be an ironic mod.....
My current commuter is a Chevy Spark EV that I've been driving for about 6 years now. The factory stereo is so bad I wish they hadn't even bothered installing anything. The problem is that the head unit has some functions for the EV system, so it needs to stay in place. So I bypassed it entirely. The Alpine PWD-X5 is a powered all in one subwoofer that also has a built in 4 channel amp, and comes with a small control box with a volume knob. You directly connect your audio device with an aux cable or bluetooth. You connect 4 speakers directly to the unit along with power, and that's all you need. Unfortunately, that unit is discontinued now, but there's likely similar products from other companies.
Post in thread 'My 2016 mod thread' https://www.mychevysparkev.com/threads/my-2016-mod-thread.9545/post-29813
