I don't know how they're set up yet, but my Geo has the tailgate-mounted spare tire. The jack and lug-wrench are mounted under the passenger seat. These are things that are probably completely absent on the prototype.
Yeah, behind the seat is one place I thought of, people seeing the prototypes have said there was surprising space there, but if it doesn't come with a spare be default? Or maybe it will come with a donut spare somewhere by default and it just hasn't been mentioned.
atreis
SW Ohio
Since a spare at all seems to be an add on for the slate, this all does need to be a consideration, and slate should come up with something more than they have before launch. I know some cars don't come with a spare, but those have run flat tires. Do any vehicles just by default come with no consideration for flats?
Come to think of it, even with the tailgate spare, where is the jack?
A lot of cars these days come with a can of fix-a-flat and an air pump. My Ariya was that way, and so are the Prius, Tesla, and many others. Interestingly, the FWD Ariya has room for a spare under the rear deck if one removes the foam insert, so I did that and have a full-size spare now without taking up any above-deck storage space. It does take a little of the hidden space. A donut spare would have fit without taking up any of that either, but I decided to go with a full-size spare.
I do a lot of long-distance trips and will want a spare with the Slate too. I prefer full-size, but can live with a donut.
I did quick dive into space saver donuts. 🍩
The wheel for those is three inches narrower than the stock wheel (4" vs. 7").
There are lots space-saving tire sizes that fit on a 17"x4" wheel.
There's a vendor in eBay that specializes in selling "original spare tires". Prices are reasonable, however...
If you're buying a used spare tire, age of the tire would be something to watch out for.
We don't know wheel specifications, so finding a wheel that fits is TBD. Obviously you can buy a new, fresh tire once you have a wheel.
An available size that's not too far off in diameter from the stock 165/90R17 size is 165/90R17. Here's how those two sizes compare:
Slate Auto Pickup Truck Using Rear Footwell Space for Spare Tire Storage (Design Ideas) Compare_165-90-17_Spar
With this idea and similar: I haven't seen any photos of the space behind the seats. Even if there were some, they are prototypes, and I thought of one possibility.
It's possible that there is no wall between the "footwell" and the cab, making that space accessible behind the seats in pickup configuration, for storage.
Does the Truck come with a spare tire??
Or maybe a spare in a can??
You can get the rear mounted spare as an option. I don't like the rear mounted tire on a pickup, the kind they put on SUVs, behind the tailgate. No room under the bed like other pickups.
Instead of the rear-mounted spare I'm probably going to go with run-flat tires.
I found a 19" tire size that has both run-flat capability and an adequate amount of sidewall to suit my preference for some sidewall in a tire -- 235/55R19.
Compared with stock size:
Slate Auto Pickup Truck Using Rear Footwell Space for Spare Tire Storage (Design Ideas) 235-55-19_Compar
Space saver spares are a good option - something with the same or very close outside diameter and bolt pattern, but only 4" wide. Better than a true donut, and easier to store than a full size spare.
My MachE didn't come with a spare (very common these days), but after the fiasco when I had my sidewall get torn out by construction debris on I70 during a snow storm, no roadside assistance available (call the number all you want, they may not be able to make it), I ended up getting a spare.
In my case the 2017 range rover evoque was sold with a compact spare, 155/85R18, same OD as the MachE 225/25R19 stock tires. Bought one on eBay for $100, bought a bag for it from Modern Spare, and now it sits in the trunk on long trips, or when I'm outside of cell or easy roadside assistance range.
Once we know the bolt pattern, I think we'll see a lot of options open up.
