Tran
Explorer
I asked about flat towing support for the Slate truck and here was their confirmation:
Hi Joe,
Great question! Towing a Slate behind a motorhome is exactly the kind of adventurous, off-grid thinking we're excited to see from future drivers.
We're happy to share that flat towing is actively in the works to be supported for Slate, including highway towing behind larger vehicles like RVs. Stay tuned for more specific guidelines and recommendations as we get closer to launch to make sure everything's smooth and road-trip ready.
Let us know if you'd like to be added to our updates list for towing and travel-related features!
Cheers:+
Kathryn || Slate agent team
Saint Alban
Anton
Queens, NY
Hyundai Kona Electric
Excuse my ignorance, I’m unfamiliar with this. What does it mean for a vehicle to have flat towing support? I thought you could do this with any vehicle.
YDR37
Nope. Always check the manual to see if flat towing is supported, because it may not be. If it's not, flat towing can seriously damage the transmission. Even if flat towing is supported, there may be special instructions to put it into flat-towing mode.
You can usually flat tow vehicles with manual transmissions. But if a vehicle has an automatic transmission (which of course is the vast majority of new vehicles), then all bets are off.
You can probably flat tow if the vehicle has an automatic transmission and a traditional four-wheel drive system with a transfer case, but it may not be straightforward. For example, you can flat tow a 2023 F-150 4x4, but according to the manual, putting it into "Neutral Tow Mode" requires 11 steps, including setting "Temporary Neutral Mode", which is 7 more steps. Then there are 9 steps to exit "Neutral Tow Mode".
Try this website (or your owner's manual) for more info.
Saint Alban
Anton
Queens, NY
You can probably flat tow if the vehicle has an automatic transmission and a traditional four-wheel drive system with a transfer case, but it may not be straightforward. For example, you can flat tow a 2023 F-150 4x4, but according to the manual, putting it into "Neutral Tow Mode" requires 11 steps, including setting "Temporary Neutral Mode", which is 7 more steps. Then there are 9 steps to exit "Neutral Tow Model".
Damn, I didn’t know it was that complicated. Thanks.
EVmodeler
Doug
SW Virginia
Mach-E AWD ER IB Job 1
The Slate will likely have a permanent magnet motor. PM motors will act like a generator since they have built-in excitation (the magnets) even when “off” and can generate very high voltages when operated above “base” speed (which I estimate is in the low 40 mph range- working on a model ;) The inverter is likely designed to manage this situation (at least for a short time) in case of some kind of failure, like an HV battery fault.
Some electric axle systems are designed for adding to one axle to make a hybrid with an engine (and possibly other motors) on the other axle. Some of the Ford hybrids are of this design.
Some motor suppliers offer an axle disconnect for these applications, or even for a two motor AWD EV. The disconnect lets the axle free-wheel to reduce the drag from the PM motor when it’s not needed or used. I am not sure if any of these disconnect options have made it to production in EVs or hybrids. It costs extra, and is a relatively low loss.
Slate may be looking into this sort of mechanical disconnect system to allow flat towing. There are other ways to achieve this function with the inverter, but they may require some of the vehicle to “on” or a special mode.
There are axle disconnects that can be added to conventional vehicles to allow flat towing with a transmission that otherwise would not allow it.
And please, don’t get started on “towing with regen to charge the battery” ! Yes it is possible, but requires quite a bit of controls, and a lot can go wrong. (I have done it in a controlled environment on a chassis dyno).
YDR37
At this point, I don't know of any BEVs (excluding hybrids) on the market that can be flat towed. If it is confirmed that the Slate does have that capability, it could be the first.
I haven't checked every current EV model, so I could be wrong. If you know otherwise, feel free to correct me.
For those wondering, the reason an automatic transmission needs the engine running is because the transmission's innards require lubrication that's provided by the torque converter, which acts as a fluid pump. The pumping part of a torque converter is bolted to the engine's flywheel, hence the engine needs to be running for the pumping to happen.
I've heard that in an emergency you can safely flat-tow an automatic by running the engine at idle and shifting the transmission to neutral. Cannot confirm this, so YMMV.
This is also good info to know if we need to emergency tow the vehicle. 90% of tow companies use purely flatbeds now but there's still a small amount that will roll up with a conventional tow-truck.
It is crazy how vehicle dependent it is depending on how the drivelines are set up.
For example, I have two vehicles in my stable, a Geo Tracker and a Honda Element.
The Element CAN be towed on rear wheels via a tow-truck if it's 2WD as it's front wheel drive, but an AWD one will damage the driveline.
The Geo CAN'T be towed on rears if it's a 2WD but a 4WD can... IF it has manual locking hubs and not the optional automatic ones.
It'll be awesome if this can be flat towed, a cheap pull-behind RV solution is what those Geos were used for a lot of the time.
This does work but it's dubious at best, as you really need to hope the radiator can get enough airflow behind the RV to keep the transmission cooler temps down.
Heck, even in flat towing a 4WD vehicle that can do so, it still says you should cycle the engine every once in a while:
Saint Alban
Anton
Queens, NY
I checked lol.
“Currently, no mass-market electric vehicles (EVs) are officially approved by manufacturers for flat towing (all four wheels on the ground) behind an RV. The main reason is that most EVs have their electric motors directly connected to the wheels, and spinning the wheels while towing can damage the motors or power electronics, since there is no true “neutral” to disconnect the drivetrain.”
GreatLakes
F150 ‘16 supercab longbed! V8
I hope they come up with a good (&cheap) solution for this.
A usual way of flat towing vehicles that don't allow it, is to use a tow dolly, that just gets the front wheels off the ground. (Those dollies tend to start at $500 minimum) And junk up your campsite with a heavy, hard to move by hand object.
But the Slate having RWD wouldn't work on a dolly.
UncleMatt
matt
Maine
maverick, tesla, toyota RAV4 phev
This is a good general discussion of "flat towing" behind an RV, with all 4 wheels of the TOAD (towed) vehicle on the ground. As I understand it, no current EV will allow it.
The Slate RWD EV truck has been compared to the Ford Maverick. Specifically, the hybrid FWD version of the Maverick. This version can be flat-towed, if you can find a towbar for the truck. Other Ford products that use the same FWD drivetrain, can also be flat-towed.
The Ford Maverick Hybrid is a valid comparison for the Slate truck. I have one and have had no mechanical problems. Though there have been many recalls. All the recalls were quick fixes at the dealer, and there are Ford dealers everywhere. Nonetheless, I would rather have a Slate truck, as it is more compact (easier to fit into a garage) and also an EV. And would hopefully never need to visit a service shop. Fingers crossed.
crownmountain
Dave
Durham NC
Well there is one now..The Mustnag Mach-E. Could not believe when I found this on my car...
J
VT
Rivian R1S
You can flat tow a Rivian, under some limited circumstances. Mainly it is going to try to regen so it can’t have a full battery otherwise there is nowhere to put that power., and you ought to have someone in it to steer.... out of spec did a video on it, and the rivian team did it in the Apple+ TV series “long way home” (or was it “long way up”), that was a preproduction R1 driven by Rivian employees, and they flat towed it in order to charge it so they could then use that power to charge the EV motorbikes the shows main cast was using (the Rivian was “support crew”).
So probably not what you actually want for towing behind a motor coach. Still technically it can. As a practical matter I expect the slate is going to need a tow dolly which isn’t expensive, but it is a pain to use every time you want to go somewhere...
UncleMatt
matt
Maine
Thanks for those additional details. I was not aware.
skidoofast
Jeremy
Barnesville, MN
ford f 150, subaru outback
How does one flat tow an electric vehicle? Does the motor just free spin or do they have an electric coupler?
and has there been more confirmation on flat towing the slate?
we just got back from a trip towing our RZR on a trailer 400 miles so we had something we could biz around town with
