What would you tow?!
slateya
Minnesota
Commercial teardrop trailers are out of my price range. They sure do look pretty. There is a reddit group, lots of websites, and at least one book on DIY building. As I understand it, teardrops started after WW2 and were mostly a home built rig for ten or twenty years.
I would hope to build one for < $3000. And have a finished weight under 800 pounds. Maybe 1100# with the fixed gear, the rest can ride in the truck bed. Close enough to fit Slate towing limit in my book.
But I am curious about what the limiting factors are with Slate. Do you think it is overheating the motor?
Hopefully there would be a towing upgrade option. Certainly I think a 4000# vehicle should handle 2000#. Ideally it would get up to Airstream Bambi 16' levels, 2500#. But maybe frontal area figures into it too.
I busted my first two trucks. Making a trash run with '63 F100 rust bucket. Just a normal amount of bagged trash in the bed, but towing my brother-in-law's 10' trailer that maybe had more than it looked like. I look in the side rear view mirror and the driver side wheel is 2' out from the truck. Turns out there was a small metal plate that holds the axle in, it had failed. I did fix it myself I think. The part was cheap.
I suspect motor cooling. Tow rating applies at all speeds, grades, continues duty. A lot of cost can be trimmed by not trying to build a vehicle to stay cool and functioning with an extra 2-3.5k lbs up hill at 80 mph in 100 degrees.
Think of battery, controller, wiring, and motor. Lots to keep cool on electric vehicles.
That's what I imagine, but I'm no expert. My EV experience is limited to a 48V electric golf cart.
Hauling a heavy load uphill takes the cart out of its Happy Place. I notice it straining, but maybe it's just my imagination because I'm accustomed to being able to downshift and the cart, similar to the Slate, has only one forward gear.
The cart's motor does get kinda toasty when it's been working hard.
To me the Slate appears to be an economy car with a pickup truck form factor. It stands to reason that the drivetrain and brakes are built to get the job done without a great deal of excess capacity.
GoinPostall
Jonathan
Cedarpines Park, CA
Ass. I'm gonna be hauling ass.
In all seriousness, the most I'm probably going to haul is 10-20 bags of wood pellets. I have a wood pellet stove to heat my house, and each bag is 40lbs. My 2020 Civic can haul 10 of them up CA18 just fine, and my 1979 W150 can haul 2000lbs, but the Slate would be great for 10-20 bags.
Garbone
Did 90 miles towing a small Uhaul utility trailer with scaffolding using our MachE, got 40% less range and that cost me under $6 of electricity, My C10 would burn 6 to 8 gallons of Non ethanol fuel thru its 4 barrel at about $4 a gallon. $15 for the Uhaul paid for itself. Now for over 100 miles, yup, I would go with the gasser because DC fast charging is a rip off.
Did 90 miles towing a small Uhaul utility trailer with scaffolding using our MachE, got 40% less range [...]
Thank you for mentioning this because I was wondering how much towing affects range.
You're supposed to keep the battery's state-of-charge above 20% and below 80%, so brand new batteries provide 90 or 144 miles of range as a practical matter. 40% less range would mean 60% of those numbers, so 54 miles and 86 miles respectively.
The Slate isn't a tow mule.
Towing a trailer would kill your range.
F150 Lightning EV truck owners are reporting 50% or more range loss towing a class 3 trailer.
Then another 25% range loss in the winter.
EVs are not made for towing (yet).
Mad Mac
I could be wrong. I often am.
But maybe we are looking at this backwards.
What if we tow a Slate behind a motorhome.
If need be with a remote switch turn on the regen to charge the Slate while towing down long mountain downhills.
Then run the motorhome electricals off the Slate while camping in dispersed or unimproved campsites in addition to using it for a runabout.
Interesting thought. No need for trailer brakes, if you get it in to Regen mode on declines. Save on motorhome brakes and arrive at the next campground with more juice then you left with.
Mad Mac
Or if the motorhome has a generator
use it to charge the Slate in a pinch.
I got curious about whether I could tow my motorcycle (480 lbs) with a rented trailer from U-Haul, which is something I've done before.
AI Query:
How much does a trailer for a motorcycle from U-Haul weigh?​
Response:
A U-Haul motorcycle trailer weighs approximately 870 pounds empty. This trailer is designed to carry a maximum load of 1,530 pounds, making the combined weight of the trailer and its maximum load 2,400 pounds.​
350 pounds over @ 1,350 lbs
AI Query:
Response:
Pick-up beds are great for hauling motorcycles. Get a good ramp and I like to use a step stool so I don’t have to go from the ground to the tailgate. The Slate will shine in this area because the tailgate won’t be 4 feet off the ground like many other trucks.
That's workable for a dirt bike, but pushing my 500-pound bike that's 7' 3" long up a ramp (which I'd need to buy and then store) and into the 5-foot bed of the Slate wouldn't be a trivial task, even considering the low entry height.
OTOH trailer rental is $15 and it's drop-dead easy to put the bike on the trailer and take it off, and it can be done solo. Get a little running start and up she goes. The ramp is wide enough for you to step up the ramp next to the bike..
By the way, I was blown away by the engineering of the U-Haul motorcycle trailer. U-Haul isn't my favorite company, but whomever designed that trailer did a bang-up job. It's built like a tank and easy to use.
I have a vehicle that can pull 9,000 pounds, so there's that. I was just wondering if pulling the motorcycle on a trailer would be something the Slate could accomplish.
