What would you tow?!
ottox914
Minnesota
2016 Audi A3 Etron hybrid
I am hopeful for a 2" receiver option. Our bike rack uses that size and I'd rather not need the converter if I can avoid it.
Kia Forte Koup
The one video where they showed a Slate with a tow hitch (the one where they towed a U-Haul trailer through the desert) had what looked like a 2" receiver. It was a pretty brief flash though, and there's still nothing on the configurator.
A tow hitch and 4-pin flat plug are the only absolute requirements I have. All other accessories I might buy are for fun.
AeroWolf
Tidewater Va
GMC Sierra
Local Civic Club Parade Float for less than 10 miles, though likely over the Tow limit.
tgpii
Thomas
New Lenox
2023 Chevrolet Bolt.
Broken Cybertrucks and briken ICEV!
Ronnie
Ronnie
Virginia
Toyota Tundra
Perhaps the the bumper has a ball mount? This is the way pickups used to be. I am fine with that. Hopefully the wiring harness will have a plug to allow the connector of your choice. I will be towing a small boat occasionally.
The standard bumper in the maker has a flat under the license plate, like those older pickups, but the upgraded one doesn't. Someone really should have asked Chris about where a hitch would be for towing when they had questions open for her to answer.
I wondered if bumper mount hitches were no longer used due to impact absorbing bumper requirements, but it looks like pickups may be exempt from those requirements. So just maybe the standard way to tow with the slate is pop out some plugs, pull out a wiring connector and put in a ball.
Kia Forte Koup
I did. I got a comment about how of course they are going to offer a hitch. Just keep an eye out in the maker, it will be there soon... It's still not there.
A proper hitch gives you the ability to adjust the ball height whereas the step bumper you are stuck with the height of the bumper.
Ronnie
Ronnie
Virginia
Toyota Tundra
Yes but for a utility trailer or small boat that is not a big deal. For a heavy tow vehicle, yes I would want a proper receiver
RedJoker
Ford Transit Connect
With 1000 lbs limit how much of a concern will that be?
For me, it's more for the angle of the trailer. The smallest harbor freight trailer that was perfectly level when attached to the hitch on my Shelby Cobra kit car will be tilting up quite a bit on my Slate with 2" lift. That greatly increases the risk of the back of the trailer dragging when going over bumps / driveways / speed bumps / etc.
