I'de guess that the OP was talking about the HV battery replacement not the LV battery replacement.Everything Tesla does is kind of expensive and proprietary And they don't want you working on it. Since slate does want you working on it, I'm guessing we're going to find out how this system works without out the Cloak and Dagger. Pretty much any new vehicle has some type of battery management system but I've never heard of replacing it with the 12-volt battery. On the Maverick hybrid You replace the 12 volt battery and then recalibrate the system Which you can do yourself. You would have to guess there would be some type of calibration of a BMS When you replace the 12-volt.
Oh maybe your right. HV and LV would both have a battery management system. I would think if you were going to the effort to replace the HV battery And the expense and not writing off the vehicle near end of life (out of warranty) It might have gone down because of the BMS So could be with it? It's kind of like replacing an engine on a car with 300,000. You kind of guess the transmission might be next or also bad.I'de guess that the OP was talking about the HV battery replacement not the LV battery replacement.
I remember getting a nice OBD Reader and telling my mechanically-inclined friend about it. He then schooled me about the prevalence of "second-order failures". I was a bit crestfallen, but still happy to have the tool.In reality, the BMS doesn't really fail that often, but the errors start with "BMS_" make it seem like the BMS is the culprit. The BMS is just the messenger, and you're not supposed to shoot/replace them.
