Not likely. They'll be slated for things like weld inspection (some of which will be destructive), structural stress testing, etc. Odds of having a robotic chassis assembly line "good enough" on the first try are pretty low. This is normal procedure. Build a small lot (enough that you can get statistically significant results), test, tweak the process, repeat. I wouldn't be surprised if it takes a dozen small runs to get the bugs worked out.Could they be the first to enter into production?
