Sound bar - factory mounting location under dashboard
Cody
Cody
NY
Mini
Didn't notice this until now, but great to see that sound bars will be easy to install / mount on the Slate truck dashboard. There's already a factory rail / clip for it.
Slate Auto Pickup Truck Sound bar - factory mounting location under dashboard sound bar install mount slate truck
BYO Sound System/Sound Bar
The dash comes prewired with multiple USB-C ports, numerous lidded cubbies, and a rail running across the bottom, to which accessories can be mounted. The center cubby is precisely double-DIN sized, allowing easy mounting of an aftermarket head unit. Or just plug into your phone, which mounts easily to the factory installed universal phone mount, with speakers in the other dash cubbies or mounted to the rail along the bottom. Similar mounting rails are found on the bottoms of the doors, in the pickup box, and elsewhere. Or, you know, just clip a Bluetooth speaker to the dash, as seen above.
Has anyone ever used a bluetooth speaker as their car speaker? It's cool... when your speaker breaks. But it sounds horrible and is NOT a permanent solution
5ohbrad
Brad
Mansfield, Texas
Nissan Frontier
While I am relieved to see a double din install being accommodated, I’m curious to see how the added draw of a stereo and 2 or 4 speakers impacts range.
memphsi, tn
Negligible impact. We’re talking watts, not kWs. Nothing to worry about.
memphsi, tn
I think the removable Bluetooth speaker is a theft magnet.
if we do get a slate I’m planning on a double dstereo hardwired to real speakers and it will support wireless Carplay + have a real volume knob!
Theft proof, simple, low cost, and I can keep my phone in my pocket if I want.
im fine with slate not putting in a factory infotainment center as long as I can add my own.
5ohbrad
Brad
Mansfield, Texas
Nissan Frontier
Boy if that’s not a sign of the times! A hardwired stereo seen as a theft deterrent. In the 90’s people had pullout head units and later detachable faceplates because car stereo theft was so rampant. I’m with you on the volume knob, CarPlay and ability to leave my phone in my pocket.
I really want to know how the speakers are going to be mounted / what kind. It's hard to compete with speakers built into the doors for using that door cavity for bass. My truck has little 4'' speakers mounted under the dash and they're tinny little things.
memphsi, tn
I think the doors are designed for speakers
Toledo
E90 & Mach E
I just thought of this. I'm going to mount my Garmin XT2 Motorcycle GPS unit in my Slate. Just need to fab a RAM mount base for the Slate dash rail system. Bluetooth to an amplifier with hard wired speakers. Perfect.
