Gas vs Electric cost
coxscars
james
0Rangepop
1998 Toyota Corolla, 1998 Toyota Rav4
What’s the cost breakdown for Gas vs Electric?
FL4XE
FL
Rubicon 4XE
It depends on the cost of electricity where you live if you are charging at home. Public access chargers vary greatly, some being free, some being free for an hour or two, some having crazy expensive costs either by kWh or time. You can look on PlugShare app in your area to get a feel for it. The standard battery has a capacity of 52.7kWh and the extended range is 84.3kWh. Multiply that by your electric rate for the cost. Some utilities even have a flat monthly cost where they also install a charger.
I have a charger at home. For me to charge the standard Slate battery from 0% to 100% would cost $6.22 and the larger battery would be $9.95. Taking the standard range of 150miles that would require 5 gallons of gas assuming 30MPG which would cost about $15 here. You also have to consider no oil changes, air filter, spark plugs and all of the other maintenance that is required with a gas engine.
TRP
Louisville KY
Mach E
E90400K and FL4XE explain very well that the best case for EV ownership is if you can charge at home regularly and only use public DCFC for road trips.
Both very good examples but you should look at your local electricity rates. If you have cheaper rates, say from 9pm-7am, you could save even more.
JeffVA
Jeff
Roanoke VA
F-150
For me I would not even consider an EV if I couldn't charge it at home. It would be such a PITA if I had to rely on public charging that any savings wouldn't even matter. I would gladly pay 4 times more for an ICE that I could fill up ANYWHERE in around 2 minutes compared to finding a charger location SOMEWHERE and hoping for a spot where you can plug in for 30-45 minutes and wait. Even a PHEV would be a no go.
Cost alone is definitely not the deciding factor
Slater
Spring Hill Florida
2020 Tesla Model 3 Long Range
I currently own a Tesla Model 3 Long Range and plan on buying a Slate Truck. The electric cost in my situation is substantially cheaper than gas. To really maximize your savings it is important to charge at home or work where your costs can be as low as free (solar) or in my case about 9.5 cents/kWh.
Yesterday, I drove 133.98 miles and i used 33.78 kWh. This is a little over $3 in electric cost. If I still had my RAV4, that day would have cost me about 5 gallons of gas or over $15. This figure also does not include oil change costs.
Slate Auto Pickup Truck Gas vs Electric cost IMG_0690
Anthropod
Anthony
Lake Waccamaw, NC
2023 Mach-e Premimum, 2024 Mach-e GT, 2018 F150 5.0, 2013 Fiat 500 Abarth
Great thread so far—lots of strong insights already shared.
Just to add a bit from my own experience: My wife and I both drive Mustang Mach-Es, and we’ve found the cost and convenience really depend on your charging setup. We live about 60 miles from a nuclear plant and are on a pretty clean energy grid here in NC, with most of our power coming from nuclear and renewables. Our average rate is around 12–13¢/kWh, so charging at home is incredibly affordable.
In fact, in over two years, we’ve only used public charging five times on her car, and maybe four or five times on mine (I got it last October). We mostly charge at home and, in her case, at her workplace, which has solar panels that significantly offset costs. When we do use public chargers, the price can vary wildly—I’ve paid anywhere from 24¢ to 56¢/kWh. At those rates, the cost starts to look a lot like filling up a gas car, especially when factoring in the longer time commitment.
But here’s what I keep coming back to: if you can charge at home or work, the day-to-day convenience of EV ownership is unmatched. No oil changes, fewer maintenance headaches, and you just plug in when you get home—done. Whenever I hop back in my gas-powered F-150 or my Abarth and have to stop at a gas station, I’m reminded just how much I don’tmiss it.
For me, EVs make sense because I can avoid public charging 95% of the time. If that weren’t the case, I’d be more hesitant, especially for someone who travels often or doesn’t have charging access at home.
So yeah—like others have said, it depends. But in the right setup, EVs are not just cheaper; they’re better.
For those folks out there that don’t currently drive an EV I think they will be amazed at the difference in the driving experience between an EV and an ICE vehicle. The cost savings are nice, but the convenience of home charging and the driving experience are a key factor in my decision to go fully EV.
If you haven’t test driven an EV yet, I highly encourage you to do so.
Hooligan
Rob
Colorado
Kona EV
I had a buddy ask me this a few months ago so I dug down and estimated the cost. For our area in Colorado, charging my Kona EV from less than 30% to 100% cost less than $3 (done overnight when electricity is cheapest in our area).
Meanwhile, my previous Acura MDX that needed premium gas cost at least $60 per fillup.
Hooligan
Rob
Colorado
Kona EV
EVs are an upgrade in every way. No more gears, and I loved shifting, both my old 5-speed BMW 330i and an Acura with paddle shifters. EVs just pull hard in a perfectly linear fashion, no gears, just acceleration. Plus, the only fluid you need to change is wiper fluid. No more belts and hoses and fluid changes like ICE cars need, so your overall wear and tear might be higher for tires -depending on how throttle happy one is -but cheaper in a big way for everything else.
I just watched a video of a gal that has a Tesla, she stated she charges ONLY at home, off-peak.
she puts on 1,100 miles a month
electricity was about 4,500 KWH for the full year and cost was about $270 for the year
at equal a bout to about .06 per KWH which is about what we pay for off peak on our floor heat in our basement
she also stated the home charging station was was $1,300 installed and was reimbursed as a credit by her electric company
There is nothing like instant 100% torque.
Not mention how smooth execration is at any speed. My Lightning rides as well as a lot of luxury vehicles I’ve driven in the past.
Its really hard to explain. People need to just try it for themselves.
It really hard to explain. People need to just try it for themselves.
Ford killed it with the Lightning ride quality. Best F150 made.
That is why most EV owners have a second vehicle that is ICE, where I live 240 mile range (probably more like 200) is more than sufficient for day to day, I also occasionally pull a car trailer or dump trailer, I wil still keep my full size pickup, this EV will potentially allow me to keep my full size pickup longer saving me a 50k replacement in a couple of years
plus this vehicle has the potential for my wife to see if it will fit a need for her, it’s 80 miles daily commute for her one way
/rant:
First let me say, I have concern over allowing the Chinese EVs into the country at this moment in time. It would absolutely be disastrous to our legacy automakers. However, the battery and EV technology they are delivering is Far Superior to what we know here today.
Charging times are down to 10mins or less for a 400+ mile range. BYD has developed a whole host of electric vehicles from the small cheap in town car to the luxury full loaded touring vehicle that are far less expensive then anything we see here today.
My point is not to support the Chinese industry, it is to say the technology is available to deliver a far superior EV ecosystem then we have developed here in the USA.
Our current governmental administration says they wants more on-shoring of manufacturing in this country, yet they seem dead set on doing what they can to limit (or at least not support) the industry while keeping the latest and greatest technology out of the country.
Bottomline, the electric car industry could be far greater here than it is currently. If we can get all parties to pull in the same direction and support our legacy and upstart auto makers, I’m sure we could close the gap and deliver a much superior vehicle that out performs ICE on EVERY level.
/end rant
