Slate Camper (Shell, Topper, Pop-Up, Etc)
I’m curious as to whether or not the Slate will make for a good off road camping platform in the larger battery/Cargo Kit configuration. Even with a lift and AT tires, I don’t think it will be able to negotiate anything more technical than a fire road, but with the motor in back, RWD, and the De Dion rear axle, it should have pretty good traction. I'm actually looking more at that 1400+ pound load rating for adding camping gear and furniture: fridge with slide, outdoor kitchen drawer, sleeping cot, water tank(s), power station (or just inverter). Maybe a lightweight RTT for the roof. The best solution would be furniture that is modular and easily removeable...you don't want to drag around extra weight when you don't need it.
SlateModGarage
Rock Hill SC
jeep
I’m curious as to whether or not the Slate will make for a good camping platform in larger battery and Cargo Kit configuration. Even with a lift and AT tires, I don’t think it will
it has been done before. Small truck and light weight shell. Sure. Range extended will need be added. I hope a second battery can be plugged in for longer ranges.
Slate Auto Pickup Truck Slate Camper (Shell, Topper, Pop-Up, Etc) IMG_9221
If I can turn my FJ into a camper, I can do the same with a Slate Cargo. The key difference is that with the Slate, sliding furniture modules into and out of the truck bed is way easier than dealing with the interior configuration of the FJ. www.EigerOverland.com
Slate Auto Pickup Truck Slate Camper (Shell, Topper, Pop-Up, Etc) Thomas3
Slate Auto Pickup Truck Slate Camper (Shell, Topper, Pop-Up, Etc) Thomas8
LOL. This isn't exactly what I have in mind, but anything is possible.
JeffVA
Jeff
Roanoke VA
F-150
I think the weight and towing capacity might limit those capabilities. That's odd though because I use to tow an 18' boat with my 91 Toyota with all of 105 hp.
With 201 hp, why would the Slate be limited to towing 1000 lbs?
Good question. I wonder if that’s in addition to full load in the bed. No load in the bed and it should safely tow 2400 pounds?
JeffVA
Jeff
Roanoke VA
F-150
Hopefully these numbers will improve when they finish stress testing it. I would at least like to tow my John Deere mower in for service but even a small trailer can exceed 1000 lbs
fuzzmunky415
Al
Jeep 4xE
Tow limits typically revolve around gvw and wheelbase, and in the case of my Jeep 4xE (3.5K), specialized transmission limitation.
panjak
ksenia
Warsaw, Poland
Mitsubishi Space Runner (RVR) 1998, Toyota HiAce 2009
Why that much fixation on towing capacity? In Europe we very rarely use trailers. I drive a car for 30+ years, my daily driver is without a hitch, my campervan has one, but I never ever used it. What you guys are hauling? Boats and cars? Are you all constructors? Everything I need to take, including rather large pieces of furniture, fits into the car or on roofrack.
JeffVA
Jeff
Roanoke VA
F-150
In the US some of us have large yards that require lawn equipment that won't fit on our roof racks
For camping with my FJ, I don’t tow anything. Everything I need fits inside or on the roof. Should be the same with a Slate Cargo.
Shay
Phoenix, AZ
www.youtube.com
Ford Maverick
One of the most common misconceptions about tow ratings is that it’s about the horsepower. It isn’t. It’s about the platform stability of the chassis, brakes, suspension, and the durability of the drivetrain itself around cooling. It’s about can it handle the weight safely and will it last.
GreatLakes
F150 ‘16 supercab longbed! V8
Boats and campers are the most popular in Michigan. Otherwise just utility trailers with whatever; oh, and snowmobile trailers in the winter. We have about 1 million registered boats here. (State population is ~10 million) Very pricy to get a boat slip, so most boats are on a trailer in the backyard etc. Also lets you move around to different lakes easily. But I wouldn't expect to tow most of them with a Slate, pretty sure "pleasure/ski boats" are easily 4000 pounds minimum.
I'm fixated on towing capacity because it has been a problem in the past. I had an '83 F150. Borrowed my parents small camper and cooked the truck transmission driving it home (two hours on Interstate). I learned that trucks need to be setup for towing (extra cooling, etc). That truck was probably rated for 3000#, and the small camper was 4500#.
(are you near Warsaw PL? or is that a nod to the Slate factory)
panjak
ksenia
Warsaw, Poland
Yes, I live in Warsaw, capital of Poland. That's what it is :) I know, it will be a long time until Slate makes it to Europe...
I’m thinking of a pop top like how vw did it but maybe straight up add the grill small fridge me bam but also waiting for more after market people to see if anyone is thinking of adding a 4x4 kit would be cool to see but probably as much as the truck 🥲 or adding just a pop up roof tent would be cool to let’s see just how off roady people can make it
