Aptera-style solar panels in SUV option.
catiare
Gabriel
Miami
Fiat 500e
I'm thinking this could be an option. The current aptera prototype can produce 545W of power from the solar panels in the vehicle body. If the base Slate (with a 52.7 kWh battery and ~150-mile range) had solar panels like the Aptera’s 545W system and sat in full sun for about 6-8 hours a day, it could hypothetically gain approximately 9.31-12.41 miles of range per day from solar alone. This could significantly offset light local driving or commuting — especially if the vehicle is parked outside during the day. Thoughts?
lgerger
MD, USA
Tesla Model Y LR
Good idea on the surface, but they seem heavy and seems like they would kill your range. But it seems like if they are effective enough, the range would not be as much of a concern, as it would charge as it drives, right?
I can easily see the roof panel portion of the SUV/Cargo topper receiving a flexible solar panel. If building out a camper with RTT, solar panels can go on top of the RTT.
UncleMatt
matt
Maine
maverick, tesla, toyota RAV4 phev
A solar roof might be a feel-good add-on to the truck, particularly in the long-roof form. But there would be some added complexity to allow the solar power to actually supply or boost the huge lithium battery.
So, let's see the actual pricing of such an option, from the OEM.
Oh, I am sure that that savvy DIY'ers are already scheming on how to add solar panels. And i look forward to seeing youtube tutorials on that. But for me, it would need to be a product or accessory that was designed (and blessed) by Slate. Ideally, as a plug-and-play addition to the stock truck.
I am beyond the age where crawling up under the dash is a fun idea.
Good luck to those who carry this concept further.
Slate uses NMC, not lithium.
raybythelake
Ray
Cleveland OH
BMW i3
You're right. Traditional rigid panels used for residential rooftop solar systems (typically with aluminum frames) can add weight. Perhaps 25-50 lbs. or more depending on size (e.g. 100w, 200w, 400w panel). There are many aftermarket portable solar panels that are considerably lighter and designed for camping and easy handling. I think the key question is how to get whatever electricity you could produce from whatever panel(s) you have back into the Slate main battery. One component that would be needed is some sort of MPPT solar charge controller and a charging connection to Slate's main battery pack.
catiare
catiare
Gabriel
Miami
Fiat 500e
The idea would be to team up with Aptera to use their tech. Their solar cells are embedded in the body (are very light supposedly) and the MPPT and other electronics are design to be part of the vehicle system. They already have some sort of agreement with Telo and they will offer it as an option.
catiare
catiare
Gabriel
Miami
Fiat 500e
I was thinking more in terms of Slate licensing Aptera's solar technology.
https://aptera.us/licenses-solar-technology/
raybythelake
Ray
Cleveland OH
BMW i3
Yes, excellent idea.
Sparkie
Sparkie
Massachusetts
Bronco
In my mind, I hope Slate Auto remains focused on their "keep it simple" design philosophy with your suggested licensing in the reverse direction. Namely, let Aptera license FROM Slate whatever they need to build the solar panels as an aftermarket sale to Slate owners.
Adding solar to topper roof is on my bucket list of ideas. If I could squeeze another 10 miles during a Costco trip, I’d be ecstatic.
but I’m all interested even if it’s just additional 12vdc. Seems many of my accessories/mods involve power.
i’ll be 80 yo when I get my Slate but apparently not the oldest. Looking forward to DYI.
Gosh I sure hope Slate has no dealings with that dumpster fire of a company called Aptera. They've been teasing and teasing their "revolutionary" car for over a decade now and continue to woo the unassuming public with hype and smoke. Aptera is just the EV version of Elio Motors.
UncleMatt
matt
Maine
Hi: It would seem impractical to think you might be able to "hard-wire" the DC solar output from a solar panel into the DC charging system of an EV. Perhaps someone could figure it out, but I suspect it is not simple. And might void your warranty.
Your idea of getting 12 Volt power is probably valid. As you can, fairly simply, apply the DC output of a small solar panel directly into the 12volt battery, with probably needed a charge controller to keep from over-charging (and cooking) the 12 volt battery.
But it would be nice if you could "collect" solar DC power to be used later.
I am wondering if a LFP home battery storage unit might be the reasonable intermediate between solar panels and the EV charger.
You can look in Amazon and find any number of "solar generators", with or without included solar panels. Jackery, Bluettie, etc. Link below.
Once you have charged up your "home generator" (LFP battery) then you can use the 120 volt AC output from the generator to power up your EV charger (EVSE or Mobile Connector).
Happy to hear other ideas. Thanks for keeping the discussion going.
https://www.amazon.com/s?k=solar+ge...+generator,aps,128&ref=nb_sb_ss_ts-doa-p_5_15
