Factory Installed Options!
I don't know if this has been answered or not, apparently there are parts of this forum I had not seen until today. Anyhow, I sent a question to Slate Auto about options, like different seat covers, wheels, bumpers, if these would be factory installed or if we would have to install them ourselves. My original thought was that all Slates would be delivered plain with no options, and options had to be installed.
I got my answer.
Slate Auto Pickup Truck Factory Installed Options! IMG_2630
Kit352
United states
Jeep wrangler
As there should be. I would opt to install most myself just because I could but things like the wrapping or having to do with the electrical of the car I would happily pay extra to have someone do.
I hope that the "1 Slate fits all" approach means that things like harnesses for optional fog lights or power windows are standard on all trucks, so that adding those options after the fact is easy.
I know for many automakers, using one harness for all vehicles is actually cheaper and easier than having different harnesses for each trim level/package/option. I'd like to add fog lights, and am hoping that it's a relatively simple wiring job.
Undoubtedly there will be fees involved.
Hopefully, if the part in question involves a swap out (bumpers, and wheels, for example) the cost will be less since you are effectively selling the stock parts back to them.
craigsnedeker
Craig
Silverado
From what I heard, they will install addons for you, but you can also do it yourself and there will be a library of video tutorials to help.
Memphis
Id like the lower stance to be a factory option. I’d rather purchase just one suspension than have to buy a normal height then rip it out for a lowered set. Seems expensive and wasteful.
I think the wiring harnesses for fog lights, power windows, audio and speakers will have blank connectors in place so most electrical options should be plug and play.
The Lowering Kit could possibly be as simple as replacement shock spacers that are smaller (shorter) than the default shock spacers.
If they wanted to they could design the suspension to have adjustable ride height with no parts at all, just adjustable shock towers or spring perches or something of that nature.
Memphis
As long as the proper alignment geometry is maintained I’d be fine with that, but in general I don’t think it is wise to mess with suspension bits that could change a tires toe, camber, castor and thrust angle.
