Slate’s BYO Infotainment and the possible issue of Temperatures.
SlateShift
Javier
Tesla MY
While i for one love the idea i can swap whatever tablet i want, whenever i want. However, there is a major concern i have with this idea. I for one live in the Dry Hot state of AZ and our cars tend to go far beyond 130 degrees Fahrenheit. So with that in mind having a tablet not designed to be in the heat… like automotive infotainment systems usually would be. This in turn could be a fire hazard or at least mean the destruction of said tablet if left in the Slate. That being said one could say id have to take my “infotainment” with me whenever i leave the to avoid such risk. This adds a bit of inconvenience to the experience, and i am sure for those in colder climates might also have a similar issue.
Input your thoughts and ideas down below.
Well I’m going to use my iPhone so it’s a non-issue for me but yah I get that. I live in az to but I’ve left tablets and other electronics in my truck before with no real issue beside it being hot to the touch. I’d recommend you get the center console add-on and put it in there when you leave the truck for a extended amount of time because I think it would be safer and will also prevent anyone who sees it and try’s to steal it door lock and all that is good but glass is glass.
You are raising an excellent point on real world conditions that have yet to be revealed until Slate makes its debut. The operating temperature range on most iPhones and iPads is 32-95F and performance outside that range becomes highly unstable to non usable. I’ve received high temperature warnings where the device exhibits erratic operation and then just shuts down, except for SOS emergency calls. Which means leaving your device inside the vehicle when parked is not advisable. Most people will obviously take their phones with them when parked, but the tablet will likely stay in place or removed from sight.
OEM in-car electronics and infotainment systems are much better designed for extreme temperature as many have thermostatic integrated cooling fans. The good news is you don’t need the device to drive the Slate, but app controls, range, music, etc. will likely be unavailable in extreme conditions.
Regarding the vehicle at large, I’m sure there will be other surprises that develop after exposure to real world conditions that cannot easily be replicated in development testing. Usually it’s a combination of environmental stresses e.g. temperature cycles, shock, vibration, humidity, etc. that may lead to premature failures on vehicle components. I’m sure that Slate will source components from proven suppliers which will lower their risk to potential defects and warranty claims.
Having lived in a hot climate, I've experienced thermal throttling and shutdowns with almost any mobile device or tablet. Since Slate claims the BYOD isn't mandatory to operate the car, it shouldn't matter. If you absolutely need a nav screen though then a purpose built infotainment device is most likely the answer like those single din android devices.
MTD
FX2GV 0
Just remove your Alpine digital cassette deck, and take it along with you with the built in handle, maybe even put it in the bag with your car phone. Also, don't forget your Ray-Bans, gotta look cool when not with your wheels.
Slate Auto Pickup Truck Slate’s BYO Infotainment and the possible issue of Temperatures. Used-1988-Lamborghini-Countach-1616187799
SadRobot
Los Angeles
2019 Wrangler 2dr JL
Where I live it's generally understood you don't leave anything in your car when it's parked and if you do, expect it to be stolen when you get back. For that reason alone I'd never use my tablet as a screen in the Slate. I don't want to drag it around everywhere I go plus it would just be one more thing to constantly keep charged.
Well with over 70 already produced I’m sure there has been some real world testing and will continue to be real world tested.
over the next 15 months they will likely have some of those 70 produced get some miles on them in many different environments
I don’t disagree with you but it’s impossible to simulate the unique combination of circumstances that lead to failures. In many respects, we as early adopters, the “end users” will undoubtedly reveal design flaws in the Slate. Same as Microsoft, Apple, and well established automakers. Slate is staffing up talent to transition from development to production as we speak.
Pretty sure the Slate tablet mount has a charger like the phone mount. I could be wrong tho. But I agree, I'll also just be using my phone.
very very willing to volunteer as a Beta tester. tropical environment.
already thinking that as I hope to be one of earliest owner on the Island I should print up some Slate Approved contact cards. For a small consideration maybe a vinyl door sticker?
Thanks for posting this! I've been wondering the same thing.
Maybe someone will invent a little phone-sized solid-state refrigerator that draws power from the main battery. A FoneFridge!
Or a Cooled Console... or something.
A ruggedized CarPlay / Android Auto screen could also serve the purpose. I did a brief search and the only thing I found that comes close is for motorcycles.
Slate Auto Pickup Truck Slate’s BYO Infotainment and the possible issue of Temperatures. Rugged_Motorcycle_Carplay_Screen
If you search Portable android auto you will see some bigger ones.
I did that. As far as I can tell none of them are explicitly ruggedized to withstand extreme temperatures.
The motorcycle one purports to work in scorching heat, but even that doesn't mean it would be able to remain in a vehicle and withstand Arizona heat or (fill_in_the_blank) cold for years.
I’m pretty sure I had that same head unit in my old 325i…
