How does that rear window work on the SUV?
I keep watching this video clip for answers. It appears you are correct, in the standard 2 seat pickup, the rear glass is fixed in place. What looks like hinges are actually covers for fasteners to secure the glass to the roof halo section, not functional hinges. When you install the SUV kit, you swap out the bolts for actual hinges. The lip on the bottom of the glass allows it to be locked in place with the tailgate. So, no latch is needed. Just a lot of fingerprints on your rear glass every time you flip it open or closed.
Makes me curious if someone will make a kit for keeping the hinges on the base-cab model. Imagine the flow-through ventilation you could get with a flip up rear window...
Pop-out for that window would be fantastic.
TFL Video
Good catch with that video. It does look like the window is captured by the tailgate. The tailgate "door card" looks to be swapped out as part of the SUV kit. And I caught a glimpse of the lower ball stud finally, which indicates gas springs will hold the window up. Which now poses the question as to how the upper ball studs for the gas springs attach to the window glass. On my Bronco they are glued to the glass. But with my Bronco, there is a whole lot more seal material to keep the tailgate/glass water-tight.
Details.
Slate Auto Pickup Truck How does that rear window work on the SUV? Screenshot_20260303_145318_YouTu
There are still a lot of details missing about this truck. I keep harping on it, but none of the walkaround videos, influencers, etc. still haven't asked about sealing out water intrusion.
In pickup truck form, we still do not know how the removable front bed wall and removable forward bed floor are sealed to prevent water intrusion into the cab. And how robust are these parts to stay sealed after the patio pavers you are bringing home from Lowes slam into the front of the bed, because some phone texting doofus stops short in front of you and you have to emergency brake to avoid rear-ending her.
And how does the tailgate and rear glass seal to prevent water intrusion when the pickup is converted to the SUV. Generally pickup truck tailgates do not have rubber seals. They do not need to keep water out of the open bed. Conversely, the gaps between the bed walls/floor and tailgate need to be seal-less to let water drain from the bed. And if seals are present in the pickup truck version, they will eventually get torn up with any reasonable use of the bed for pickup truck duty.
It would be nice if an internet reviewer/influencer would actually ask questions about real world use of this Slate truck and the durability of its design and construction.
But I'm a "hater". Lol.
They told me at the Ft Worth event that pretty much all of these states have been hand built prototypes, so who knows if any of them actually have any waterproofing built into them. Hopefully in June when the first "real" ones come off the line we'll be getting info on how they do all of that since those are going to be the test drive / press testers.
If I ever get to see a prototype or better, a pre-production unit, that is the first question I'll ask of the Slate reps.
I'm not trying to overthink this, but after reviewing the videos and subject matter on the rear glass I have a new theory on how it's going to work.
First, what we know:
  1. the rear cab glass is locked in place in the two-seat pickup version.
  2. the rear cab glass can be removed, but with no working hinges it cannot be tilted up in the pickup
  3. the glass and the bulkhead get removed when transformed to the SUV
  4. the "halo" is repurposed at the rear of the SUV
What I suspect will happen in the SUV conversion:
  1. the kit will include the rear bench seat, seatbelts, rollbar with embedded airbags, hard shell top, and side windows
  2. The SUV kit will also include a "new" rear glass with working hinges, struts or pistons which allow the glass to tilt up and held out of the way for loading without opening the tailgate.
  3. the original rear cab glass in NOT compatible and not repurposed at the rear of the SUV
  4. the "new" rear glass will have a modified weatherstrip seal at the interface where the glass meets the tailgate
  5. the original cab glass and bulkhead will be stored in the reusable SUV kit packaging for owners who desire to transition back to the 2-seat pickup in the future.
I hope this can bring some "closure" to the issue, ;) pun intended.
If I can get to the Slate booth while I'm at the Ft. Worth Lone Star Nationals swap meet I'll ask 'em. I wouldn't be surprised if these prototypes are bonded in on the pickups.
