- Jan 13, 2026
- 2
- 266
- 485
- Springfield, VA
- '23 R1T, '97/25 Miatas, '19 Monkey
- Thread starter
- #1
I was thinking more about fleet sales, and how a lot of fleet sales for the Lightning were because of its robust onboard inverter. This is great for power companies, remote welding, air compressors, etc. The Slate hasn't really gone into much detail about running heavier electrical loads from the truck, though forum member @sodamo o did have this question addressed by Slate last year. Chris Barman just said to "check your frunk" when asked about powering a job site.
I was thinking a much more practical modular solution would be to have a weatherproof inverter box mounted to the bed rails and secured with a lock to prevent theft. When it comes time to use it, a jumper cable from the charge port could be run to backfeed out of the battery. Since the charge port is used, there isn't anything to install or wire up in the truck itself, and unlike the Lightning's inverter, the Slate packaging doesn't have to work around anything inside the truck, hopefully making for an easier integration. Slate could easily sell this as a $1000-$1500 accessory.
The slightly more expensive option is to run something like a Ecoflow Delta Pro 3 that can simultaneously output 240v and take a 120v input. This would act as a buffer for the low AC output of the truck. They are a little more than $2k, but you can also take it with you.
