fuzzyweis
- First Name
- Jim
- Aug 10, 2025
- 5
- 70
- 154
- Southeast US
- 2000 Ford Ranger Electric (OEM), 2024 Honda Prologue, 2023 Outlander PHEV
It doesn't exactly work like that, the DC-DC inverter on an EV is set to output a specific amount of 12v power, like the one on my Ranger does 1500w, that's it's output regardless of draw, so it has power to run the hi-fi stereo, charge the 12v battery, run the hvac blower and all the lights at the same time, if none of that is on, it's still outputting that power at the ready, it's not like you turn all that off and you get that power back. Plugging in a phone charger or adding some kickass off road lights doesn't really hit the high voltage battery, it may bog down the inverter and cause it to draw down the 12v battery causing other issues, but the draw from the high voltage battery will be fairly steady.Plus on an EV halogens would just take a bunch more electricity eventually from the EV battery and range?
The HVAC heating unit(either heat pump or element) and Air Conditioner are run off the high voltage pack, and those can impact range by quite a bit.
-Jim
