3D Print Model - AI Generated, Free
dragondroptv
Chevy Spark
Here is a STL that I had a AI generate from images of the truck. I had to do it multiple times with different setting, but this one is pretty good. The file is 45MB so it wouldn't let me attach it to the post so I made webpage for viewing and downloading.
https://mcnethost.net/slate_stl
Enjoy!
Not sure the Slate will be available with a manual transmission. 😂
Except for the four wheels being compeltely unattached, this is probably one of the cleanest AI generated 3d models I've looked at. At least there's no errors showing up on my resin slicer. I might actually give this a go!
dragondroptv
dragondroptv
Chevy Spark
I thought the wheel being detached would work nice if you want to make them workable. Drill a couple holes, insert a pin, find a hill. It’s will use gravity to move like the Nicola One Semi
EJensen
Northern Virginia
Subaru Outback
I opened it up in Fusion360. There's an impressive level of detail in your model.
I don't have any experience working with meshes, so I may experiment with turning it into a solid.
Thanks again for sharing.
dragondroptv
dragondroptv
Chevy Spark
I've added some additional STLs. I'm working my way through the entire Starter Pack Builds. I'm also going to try to have some made of just the interior.
