Electric Windows Configuration.
2thlesswithta2s
Ron
NY
Subaru Toyota
Although the hand-crank windows base feature is what got my attention regarding Slate's simplicity, upon reflection I think I may actually want power windows. It depends on how the switches are configured. You see I'm becoming old & infirm & would rather not lean across to the manual crank on the passenger side to get extra ventilation on hot summer days. I can't tell from any images or descriptions I've seen. Does the kit include 2 switches on the driver's side?
doubt it. most likely it is a motor that attaches directly to the crank gear. They sell these on amazon.
You could certainly run a wire across the truck to control it from the center console, or driver armrest.
I believe it does, that's what the image in the power window option in Maker shows:
Slate Auto Pickup Truck Electric Windows Configuration. button
Or compare the driver-side switch in the Maker with the passenger-side switch after adding power windows:
Slate Auto Pickup Truck Electric Windows Configuration. 2026_06_17_16_54_52_Personalize_Your_SLATE_Make_It_Yours_Mozilla_Firefox
Slate Auto Pickup Truck Electric Windows Configuration. 2026-06-17 16_56_29-Personalize Your SLATE _ Make It Yours — Mozilla Firefox
Seems clear that there are two switches on driver side and one on the passenger side.
2026-06-17 16_56_29-Personalize Your SLATE _ Make It Yours — Mozilla Firefox.webp
I am wondering if these will be plug and play, the doors are already wired and all you need to do is attach and plug them in. When I put power windows in my Canyon I had to remove the door panels and fish the wires through the door boot, then all the way over to the passenger side and fish the wires through that door boot too, a real PITA.
If I have to do that with the Slate I will just get that accessory added at purchase.
When I repaired the burned-out window regulator in my Sequoia, I had to do that and then reseal the plastic sheet between the door cards with nasty sticky black butyl tape sealant! I'm optimistic that if it's designed so that these user-facing upgrades/repairs offer slightly cleaner routing options. It's fine, I've done it before on a vehicle for which the engineers were only thinking about profit and assembly line convenience not designed for repair and customization, I can do it again (but personally I'm looking forward to window cranks), but I imagine it might be a little easier and cleaner.
slate808
Mark
HI
Tacoma, Ram
Thanks for posting this thread. The power windows setup was one of my questions for possible upgrade and long term maintenance.
I'm wondering if they made the door trim panels easy to remove and replace. My guess is yes, they thought of that. Because you would think inexpensive power windows are going to be one of the most popular upgrades. I wouldn't be surprised if they're listed as standard next week. Not counting on it, but it would not surprise me.
GrizzlysGhost
Montana
I consider roll-up windows as almost part of Slate's brand. Tons of articles have made it a point that Slate is so basic, "it even has roll-up windows!"
slate808
Mark
HI
Tacoma, Ram
I have never had a NEED for power windows but there are a few instances where power windows are convenient. My old Tacoma has crank windows and I get by with them just fine but I will consider the Slate power window upgrade, depending on price and diy maintenance.
If they do, I'd pay $20 for an "upgrade" to go back to hand-crank windows just for the nostalgia factor/uniqueness.
slate808
Mark
HI
Tacoma, Ram
I might actually start with crank windows and get the power windows separately if the install is straightforward. Keep the cranks as backup.
That is my plan.
I wonder though will the price be more installing them when you buy the truck or if you buy the kit and install it yourself.
At the factory you have to pay for the labor for the conversion since it is done after the truck is completed.
Same for any accessory you get.
GrizzlysGhost
Montana
That is my plan.
It will be nice to find out about the "spare" parts as well; if you have the switches installed prior to delivery to you, will the crank parts be shipped to you as well? Will they keep the parts and "recycle" them back into the assembly line? Will you receive some sort of discount for not receiving the extra parts?
'23 R1T, '97/25 Miatas
If you order power windows, I would almost guarantee they will ship you the truck with crank windows, and you will just make the conversion yourself. The single config allows them to be more efficient.
